LIFT chair for insi...
LIFT chair for inside the sidecar
15 Users
188 Reactions
On a serious note, does anyone here have any info on a LIFT chair, for mounting inside the sidecar ?
A chair/seat that with the push of a button can LIFT the passenger UP, making it easier to get their feet under them, and easier to exit the sidecar.
To be frank and forthright, some of these sidecars are a M%&%^$F%&^&%$ to get seated into, or to get up and out of the seat.
I can not understand how a modern day sidecar manufacturer can build a sidecar/seat so that only a 13 year old gymnast has the physical abilities to sit down into, and extricate themselves from the sidecar seat.
If anyone knows of a lifting seat, like those used for disabled people, that works in a sidecar, please let me know.
Posted : October 13, 2024 9:39 am
MJ, Brstr, kevin and 2 people reacted
Gymnast has to be at least 18 in most states.
On the Hoosegow forum someone has done this.  Chair rose up on rails.  I can't remember the title of the thread, and if he used a standard chair on vertical rails (scissor frame?) with a linear drive(s), or if the seat itself was special.
Another great idea was the gentlemen who cut the nose off his Ural, and hinged it.  The whole nose swings open and the seat is right there.  If someone can take a couple of steps backwards, they can then squat into the seat.  Thought that was really cool.
Posted : October 13, 2024 9:56 am
Am considering this: https://www.liftmychair.com/
EnhanSit....it's a 3" high mechanism that can raise and tilt a standard recliner, or chair seat (think sidecar seat).
It is certainly NOT cheap, or inexpensive, as they want well over $ 600,00 for it, including delivery.
But, that may be the price that needs to be paid, to make life easier for my Monkey Boss.
Posted : October 13, 2024 11:50 am
Thane Lewis, Brstr and sheath reacted
(@kevin)
the old watsonians had that problem, with their huge windshields . they had a hinged cockpit lid from the factory, as well as a cutout in the side so you could kind of roll out and fall on the ground.
my 68 monaco has both, but the cutout is worthless because its on the left-- the british side-- rather than the right where an american would fumble their way out of the chair.
homemade options are available
This post was modified 1 year ago by kevin
Posted : October 13, 2024 2:18 pm
Just saw this video.  Looks like a similar setup to what you are considering, but without tilt.  No info on how it was done.
It does show very limited room in the up position.
Better video if you go to about minute 2:40 you'll see it function.
And now the rest of the story... (aka the real reason this Royal Chariot has a seat lift).
Posted : October 13, 2024 4:27 pm
 Drew
(@andrew-baker)
I posted this ad a while back.  Maybe talk to Hannigan and see if this is something they did or the owner did later.
Here's the forum post.  CL ad link is dead.
https://sidecar.com/forum/hacks-for-sale-from-around-the-internet/2008-honda-gold-wing-with-hannigan-16000-wood-river-il/#post-84273
GoldwingHAnnigan2
GoldwingHAnnigan3
GoldwingHAnnigan
Posted : October 13, 2024 5:16 pm
Thane Lewis, Brstr, sheath and 1 people reacted
Middle picture in Drew's post sure looks similar to the setup in the Yellow Chariot of Joy.  Hope it is an option you can just purchase.  👍
Posted : October 13, 2024 5:54 pm
Here's one that runs off a 14.8 volt battery.  Around $600.
https://vocic.com/products/maidesite-heavy-duty-floor-lift-chair
They also make a lighter duty one for under $400.
https://vocic.com/products/lightweight-electric-bath-lift-chair
Reviews on Amazon.  Apparently takes about 2 minutes to go all the way up.  But since it's battery powered I wouldn't expect the motor to be fast.
I'm wondering if it runs on 14.8V DC power, if it can be powered by the bike?
Kind of  silly video to go with --->
But you get the idea.  Would take some futzing to make it work in the sidecar.
Posted : October 13, 2024 7:35 pm
A I started to type a square plate but immediately corrected myself.
A round plate fixed to the foor.
And another fixed above to the seat.
With a small explosive charge fitted between.
Oh!
I can hear it now....
Bang!
Your fired....
OK second attempt..
The scissor lift mechanism from a bike lift or similar.
And an airbag operated by a suitable compressor.
Expelled air can be discharged through a suitable trumpet to tuned to make royal carriage sounds.
Er or through a set of pipes.....
Bagged of course.....
My Watsonian is a challenge for the bride to get in and out of and she is smaller and reasonably nimble still.
Thinking about the non functioning chair lifts that came with our 2 story house.
They have various sensors to prevent I assume overload and or injury.
Powered things require a healthy respect to be able to retain things like digits and limbs in a fully functioning state.
463077252 10161701333632488 1091600359924331360 n
At a car and bike show yesterday.
Photo by bride.
This post was modified 1 year ago by Brstr
Posted : October 13, 2024 8:06 pm
double scissor lifts for example as the ones used for to jack up motocross bikes. So when you got a flip nose on your tub (like my first MZ superelastic had) and a individual car sear, then you could fit the jack under the seat and crank it up with a electric motor or battery drill.
Just a thought.
This post was modified 1 year ago 2 times by Peter Pan
Posted : October 14, 2024 11:23 am
MGV8, SANTA CLAUS, FlyingMonkeys and 3 people reacted
IMG 8597
IMG 8596
let's have a try, if I am able to post the photo
Posted : October 15, 2024 11:08 am
Thank you  all. I have  things under  control  now  (ha ha ha ha ha) (said in an evil tone) Razz
I called  Hannigan  Sidecars  this morning,  discussed  their electric lift chair. Wish I had  known  about  this 4 months ago,  before I  picked  this  rig up from  Hannigan's,  as I  would have  had them swap out the  existing  chair for the  electric  lift chair.
At this point  I  have a  different  remedy  in place,  and will  see IF it works. If not, then have  Hannigan's  ship me the $ 1,300 electric  lift  chair,  that  will  probably  cost me  a wheelbarrow  load of quarters  to ship from  Kentucky to  Washington,  but.....what  the hay !!!!!
Time is getting  short, as I am  scheduled to  ship this  entire  sidecar rig  in early  January...Washington State  to Florida,  then in mid February...Florida to  Heidelberg,  Germany.
Everything  else is  100 % complete and  ready, just  need to  make it easier to get  into  and  out of the  sidecar  seat. Excitement
Posted : October 15, 2024 12:04 pm
MJ, Ben Franklin, Brstr and 2 people reacted
One thing to keep in mind, at least as I recall "seeing," is the lift apparatus under the Hannigan lift chair raises the static seat height, perhaps enough for a passenger to rub his/her head on the hard-top, if so equipped.
Posted : October 16, 2024 6:23 am
Dann wünsche ich viel Spaß auf beiden Seiten des großen Spuknapfes.. Then I wish you a lot of fun on both sides of the big spit pot.
Be careful when you ride those beautiful roads up into the Odenwald and Black forest. Each year quite a few youngsters find themselves as a radiator grill on those gorgeous bends. You will find more rig meetings only in South Germany then on this whole continent. Check for the forum at www.dreiradler.org/
Best wishes.
Posted : October 16, 2024 10:20 am
Brstr, FlyingMonkeys, sheath and 1 people reacted
 MJ
(@mj)
We have the Hannigan lift in the sidecar of the Honda. The former owner had it installed for his wife who had MS.  I'm 5'10", and with the height of the bracket for the lift seat, it's a bit close to the windshield. Hubby moved the entire contraption back 4", so you have to be careful when raising the seat that it doesn't hit the back of the hack. It does make it really easy to get out of the Hannigan bucket! I never ride with the hard top on. My head would hit with a helmet on.
Posted : October 16, 2024 2:17 pm
2FLTC, Brstr, DRONE and 4 people reacted
Page 1 / 4
