Up keep
13 Users
142 Reactions
(@smitty901)
Β  Took sidecar off for maintenance and up keep mostly on bike this winter.Β
New car tire rear, new front tire. Brake pads all the way around.Β  A good going over for any hidden issues none found.
Facing out now . Get it out and sidecar back on soon.
Posted : February 27, 2024 4:45 am
CCjon and sheath reacted
smitty901.............Oh, The Humanity !
I shall drink a dram of MacNaughtons Scotch Whisky for all you blokes that have to remove your sidecars just to do maintenance, replace tires, brake pads, etc.
Some of us (we be the wankers) do it the easy way.
Posted : February 27, 2024 6:08 am
MJ, Gecker and Brstr reacted
(@smitty901)
Β We have one of those that will lift cars and trucks also. That is a nice setup.
I wanted it in that the bike room it is in . Also plan to replace all the mounting bolts and nuts this time around when reinstalling it.
Really want to go over every inch . Did not want any surprises on this years planned rides.
Posted : February 27, 2024 9:14 am
Ben Franklin and sheath reacted
(@reardan-tom)
Or another way. Similar, I suppose....
Posted : February 27, 2024 9:23 am
MJ and Brstr reacted
(@2FLTC)
Here is my way. It makes it easy to check the alignment, service, and clean it.Β
Posted : February 28, 2024 2:36 am
(@smitty901)
Β  Sidecar is back on the RGL.Β  As always it was a quick easy install.Β  20 minutes work then test ride all good. Rode it yesterday
Today I will go over it a check all the bolts make sure they are tight.
Wife and MIL have appointments today.Β  30 Degrees out by the time they get moving it will warm up to mid 30's I am going for a breakfast ride.
Posted : March 6, 2024 12:12 am
sheath reacted
 MGV8
(@mgv8)
One of my few regrets of retiring and selling the shop.. I didn't figure a way of installing a hoist at home.. Ceiling hight and the size of the shop.. I now do it the old way.. Jack it up and roll around on the floor. Keeps a guy in shape, sort of, well not really, more like finding all those spots that don't move or work any more.. On the body, not the rig LOL.Β
Posted : March 6, 2024 5:48 am
(@smitty901)
Β Went over the bike and sidecar yesterday found a crack in Lower frontΒ  upperΒ  support.Β  Took sidecar off. Ground it out weld and plated it.
75-80,000 on the sidecar can't cpmplain
Posted : March 15, 2024 2:18 am
Brstr reacted
(@smitty901)
Β
20240429 063046[1]
Β Β Β  Cracked welded up good. Added more steel and made it stronger.Β  Started touching up the paint in areas I welded. While it is off I am going to touch up the frame paint. May end up up just painting all of it.
I have used this paint with great results on many frame touch ups.
20240429 063206[1]
20240429 063046[1]
Β
Posted : April 29, 2024 6:37 am
Brstr, CCjon, MGV8 and 1 people reacted
I gave SYZ a good pat on the seat yesterday and told him he was a good boy.Β  That is pretty much all the yearly maintenance required.Β  😉Β
Next week when it warms up a bit the goal is a good going over.Β  This will be a big year for rides.Β  Starting with the Trans America Trail from Utah to MS for the rally.Β  🤩Β
I do have a question for all of you who work on lifts.Β  With your rigs suspended in the air, how do you "lay down on the job"?Β Β  I'm a big fan of nap time, now that retirement has settled in.Β  😎Β
Posted : April 29, 2024 9:29 am
 MGV8
(@mgv8)
@scott-h Just lower it down to the right level, get on that nice comfy creeper and roll under.. Once the nap is done, raise it back up and finish what you were doing, Or not LOL.
This post was modified 1 year ago by MGV8
Posted : April 29, 2024 11:25 am
(@smitty901)
@miles-ladueΒ
I was not going to weld on anything with it attached to the bike. To much of a risk. Been fun riding it with out the sidecar. It will go back on after the 7th.
Touch paint the frame. replace some mounting bolts ect.
Posted : April 29, 2024 5:39 pm
(@smitty901)
Β  So had some time on my hands. With tub off it was quick and easy to pull Caliper and clean it up a bit . Checked pads still good at 33,000 miles.
The pin that secures the pads was rusted. Cleaned that up.
Β Β Β  I want to get a new one but seems Bremo does not offer parts unless you have a year make and model . Well they don't list sidecars of course.
I think there is a KTM bike that use the same pin. No one even list pads by part number.
20240430 114108[1]
Β
Posted : April 30, 2024 1:31 pm
Brstr and sheath reacted
(@kevin-huddy)
Prick Member
@smitty901Β
The pads on my sidecar look similar and off a Brembo caliper used by Ducati. Β Search using any of the numbers you can see on the pads.Β
Posted : April 30, 2024 3:58 pm
(@smitty901)
@kevin-huddyΒ
I did nothing . Bremo has no support for motorcycle pads. I have a spare set coming from Hannigan. Ok for a while yet
The Ducati and KTM use different part numbers but maybe the same.
Β  Caliper all put back together and back on. Will put ECC and shock back on frame to night. Flip it over quick coat on the other side Let itΒ  cure 2 days then put Tub back on.
20240430 161254[1]
Β
20240429 090014[1]
Β
Posted : April 30, 2024 4:37 pm
Brstr, CCjon, SwampFox and 1 people reacted
Page 1 / 4
