Moto Guzzi V9 & Wat...
480 Reactions
 Drew
(@andrew-baker)
Posted by: @brstr
trying to sort the 1903 Minerva for this weekends run.
You have the best old stuff.
Β
Posted : September 5, 2024 3:24 pm
Be
IMG 20240907 170319
IMG 20240907 170310
IMG 20240907 170306
Β  Beverley run.Β
Dennis made 55klm so.almost to Northam.Β
Felt he had proved the point by then so.when it fauled the 3rd spark plug he called it a day.
Loaded it on the backup trailer and headed home happily.Β
Posted : September 9, 2024 8:03 am
smitty901, FlyingMonkeys, sheath and 1 people reacted
There was a password that I finally found. Think I removed it.
https://www.smugmug.com/app/library?imageKey=nhLBm2x
Give it a go.
Posted : September 24, 2024 6:55 am
sheath reacted
20240924 145806
20240924 151030
20240924 145539
Β Started measuring again for triple tree mods.
John said he will be selling the milling machine soon.Β  So needs must.Β
Posted : September 24, 2024 8:45 am
Posted by: @brstr
Give it a go.
Still asking me to sign in when I clicked your link.Β  Maybe we have to have a membership to view pictures on this site, and your password removal just makes them public for members to view? Facebook used to be like that.Β
Β
Posted : September 24, 2024 5:52 pm
Pity not sure when this changed.
Will have another go latter
Posted : September 24, 2024 7:02 pm
OK question.Β
How long is a piece of string type.
Stock trail is 116.1416 mm.
Well close to that.
Options are open.Β
Was thinking maybe 30mm?
Too scary?
I had to measure then remeasure repeatedly to see what the actual dimensions are.
Still not 100% accurate but guessing near enough
Should be 26.4 deg rake but I keep getting close on 30 deg.Β
The rear of the bike sits a little low but 25mm over 1480 mm is less than 1 degree.Β
According to my measurements.Β
Forget calcumalations.Β
I'm drawing it out on a piece of MDF sheet.
Thanks.
Posted : September 26, 2024 3:39 am
From my extremely limited experience on the R1100 GS with Dnepr:
Original trail (about 4" as setup with about 25% rider sag on forks, and about 30% rear rider sag) the original trail which is about 4" was very tiring on the shoulders, arms and wrists.Β  Even though the bars are over 31" wide at the grips.Β
Old DMC of Washington kit reduced the trail to just under 1.5".Β  That was slightly on the twitchy side.Β  I probably could have gotten used to it. Didn't measure rake change, but noticed that the rake change caused the front wheel to deflect off rocks, ruts, etc., due to the change.Β  Didn't like the design of the kit, or the negative effects of the dramatic rake change. Β
Dedome mod.Β  Keeps rake the same.Β  Changes steer head angle, such that trail is approximately 1.75". Β  Pretty comfortable, although if I make a new fork brace, I might bring the trail down to that 1.5" again.Β  More than anything because it seems like I'm always riding in ridiculous cross winds.Β  So a slightly lighter steering would help for those 600+ mile days.
Hope this is at least a little helpful.Β  Definitely looking forward to follow along with what you do, and your impressions. 🍻Β
Posted : September 26, 2024 9:26 am
Thanks and there is another issue you raised.Β
Taking account of sag's affect on trail.
I was thinking 30mm trail.
Then when I started drawing it out I measured 40mm.
An inch and a half is 38mm.
Will see.
Posted : September 26, 2024 6:37 pm
Figured a work around for bending light walled pipe. Should work on tube as well. Cut some disks from 1/2" MDF sheet. Sanded till they were an interference fit then hammered them in till they were 4-6" either side of the bend area. 1 plug then fine clean sand then the other plug.Β  For what I am doing it's OK to leave the sand in.Β
One day the plug will fall out and pile of sand will confuse someone.
Also old BMW teaserΒ
The trike is for sale.Β
Nope never asked how much
20241007 072945
20241007 095935
Β
Posted : October 17, 2024 6:31 am
This site saves drafts.
Still learning where they go.Β
Scratchings on a sheet of MDF.
Then shape a block of wood to see which way to go next.
Β
20241017 165647
20241017 165636
20241017 165630
Posted : October 17, 2024 6:39 am
Drop triple trees.Β
Stops the height drop when the forks rake out.
That's the aim here but what mine will look like is yet to be seen.
Messing with the wooden mock up because my friend John doesn't have my naive confidence about being able to figure it out as I go.
What could go wrong???
1100 GW revised portraits 12 11 003   Copy
650 Suzuki Bergman 007   Copy
Β
Posted : October 17, 2024 9:26 am
This one's for you Miles.
NSU
The name on the tank is a city in Germany where the bike was made.Β
This was a 35 year resto.
He ordered a new barrel from someone in Germany who did a small batch of them. Then he lost their contact info.
20 yrs went by and they placed an ad somewhere saying they had a barrel for a Steve in Australia. Word got to Steve along with the barrel.Β
Notably Steve Merrel engineered his own dies and pressed the complex sheet metal toolbox.Β  And made many other parts.Β
Didn't have much time to examine it but will someday.Β
20241013 125736
20241013 125819
20241013 125810
Β
Posted : October 17, 2024 9:51 am
2FLTC, FlyingMonkeys, Drew and 1 people reacted
20241020 165805
Working withΒ  bandsaw, a belt sander, a hand saw and a drill press. Getting close to dimensions wanted.
It's a matter of proving the design modifications from standard. The tricky bit's to come
Shame I have no CAD skills.
Posted : October 20, 2024 8:36 am
Drew, SwampFox, FlyingMonkeys and 1 people reacted
Your WAD (Wood Aided Design) is coming out very nice! 😎Β
Posted : October 20, 2024 9:49 am
Drew, Brstr, Thane Lewis and 1 people reacted
Page 3 / 13
