[Sticky] Introduce Yourself!
My apologies again.
The T-shirts. And from the For Sale section, the seller in Maine with the SoA chair.
This is harder that transitioning from two to three wheels. I even had a steep learning curve to quit putting a foot down at stops. (When I went back to two wheels, the lesson was learned very quickly.)
Hello, Here’s my introduction:
I just picked up my Watsonian sidecar attached to a 2018 Triumph Bobber last Monday. It’s been a trying nearly 3 years in the making, the delay caused by an illness with the original dealer, but Texas Sidecar Company was able to turn it around in 6 months while servicing their customers ahead of me. I’m delighted with the results. (I understand that I’m not able to post a picture until I respond to 3 posts, so I will post a picture after that.)
My first positive experience with USCA after joining years ago was a member who I contacted from the directory who drove to my house and let me drive his Ural while he rode my Bobber. My second experience was a rally in Rusk, Texas where I took my Scottie (by truck) and met other sidecar owners. Everyone was warm and welcoming.
I’m a retired 30-yr Marine and grandfather of 2 granddaughters. I started on a Bonneville, then switched to Harleys, but won’t be without both. My solo bike (now so-named) is a 2020 Softail Slim. I’m lighthearted when it comes to motorcycle brands and have been known to wear Triumph gear on Harleys and vice versa.
My focus is learning to safety drive the rig and learning the best way to secure my dog to prevent him from getting injured.
Oh dear.
If the shoe fits?
It'll be a shoe in?
It'll straighten up once you get your toe in?
Have I toe nailed it yet?
Or do I get the boot?
Posted by: @paul-mattoonHello, Here’s my introduction:
Paul Mattoon @paul-mattoon....WELCOME to the 2nd greatest show on Earth.
You have a great attitude, which...is a key ingredient for owning and driving a sidecar rig.
Where do YOU live ?
Now is your chance to make a 2nd post
@brstr Very good! I've toyed with some expression of shoestrings and eyelets on the nose of the chair.
I need to improvise a windscreen.
I found 2 3" led headlights I plan to mount to this alum. disk
Posted by: @miles-ladueReality is, figure somewhere from a LOW of $ 12.5k to a HIGH of $ 20k...all depending on your tastes and selections.
Well, I visited TSC and you were right. I have attached the quote, including the Triple Tree you suggested. Enjoyed talking with Kent and look forward to seeing him again next Saturday at the 2025 Fall Sidecar Muster, although I will only be there on Saturday.
Posted by: @chrisntxWell, I visited TSC and you were right. I have attached the quote, including the Triple Tree you suggested. Enjoyed talking with Kent and look forward to seeing him again next Saturday at the 2025 Fall Sidecar Muster, although I will only be there on Saturday.
Chris, from Texas.....now you see the light.....but wait.....as noted on the Estimate from TSC/DMC, that price at the bottom of the page does not include LABOR for the installation of the new triple trees....and then there will be new bearings and seals....and Timken Red waterproof bearing grease.
Based on that Estimate, and the need for labor to install the triple trees and associated parts, you will be very close to $ 14k....or up to $ 14,500.
Quite surprised at the cost of $ 2k to make the triple trees. It's their business, and they can charge whatever they want to, however when I bought the 3 separate sets of custom made triple trees for my Goldwing 1800's, the actual price I paid was $ 950...then $ 1,150....then $ 1,200 for each set.
And two of those sets of triple trees were supplied by the former DMC, as they had them made for them by an outside machinist. The 3rd set I bought was from Hannigan Sidecars, as they make them in-house, and produce dozens of the same kind, at the same time.
I did all the installation of these triple trees myself, in my shop, so knew the work was done right.
That Estimate of $ 2k to make the triple trees....is actually what the entire job should cost for the triple trees, including labor, bearings, seals, and...Timken Red waterproof bearing grease. All-In, $ 2k.
As I said, it's their business, and they can charge whatever they want to.
- 91.9 K Posts
- 5,499 Members
