Posted by: @miles-ladueScott, if you don't find a suitable spring in your own parts collection, (which you probably will), contact Chuck @54vintage , as he may have THEE spring on hand.
The Ural cT chassis that is being used as the frame for my cargo sidecar rig, will NOT be using the drum brake, just the backing plate, so if that spring is the same one, he may have that available.
Chuck's email is: pica-pica1@hotmail.com
Many thanks Miles. 🍻
Posted a question on Soviet Steeds to see if anyone knew of a U.S. based vendor for brake parts. May have a lead. Will keep paws crossed to hear back. Meantime I did a "double spring" install from a kit of springs. It will be a 15 minute job to change out when the correct part gets here.
Also think I figured out why the brake parts look so new. The lever which activates the shoes wasn't manufactured quite correctly, and was binding up. Most likely the original owner of the Dnepr this came from deactivated it. Did a bit of work to get that functioning correctly. Ordered a new tool which i'm hoping will fit cable so it can be properly lubricated. That should be here tomorrow. With a bit of Good fortune it should be all back together, and ready for action. 🙂
Here is where we are as of today.
Spring kit of questionable quality
Specific questionable springs used
Yung Scot, from the Highlands of Scotland, did you manually check to see that you can rotate the cam on the brake actuator, to overcome the tension of those two springs ?
And, make sure you properly lube up the actuator cam that pushes those brake shoes apart. Lube the backing plate where the edges of the brake shoes make contact with the backing plate.
Then, before installing the brake drum onto the axle, manually engage the Sidecar brake, to visually witness the brake shoes engaging, and relaxing back to the unbraked position.
Posted by: @miles-ladueYung Scot, from the Highlands of Scotland, did you manually check to see that you can rotate the cam on the brake actuator, to overcome the tension of those two springs ?
Yes sir, and even used the correct backing plate grease. Witnessed by the new Shop Foreman between snore fests on her raised princess platform right next to the work zone. 👍
This is all pretty old hat for me. In my early days at the automotive dealership, we were required to have our brake, lamp and smog license, along with our ASE master and specialty certifications. The OEM I worked for required us to maintain the ASE certifications. Up until retirement I had all the automotive and medium/heavy duty truck certifications. Stayed pretty hands on at every opportunity, as it was the more fun, relaxing part of the job.
Not something I normally discuss as it sounds like bragging. Certainly not meant that way. Just part of a very fun and incredibly fortunate career. 😊
It's not bragging, when it is the facts, and I believe everything you tell me, not just because I know you and like you, but because the Super Muttress/Shop Forewoman told me it is so.
Tool for lubricating the brake cable came in. Tool works well, cable not so much. Holes in the cable sheath alllowed lubricant to leak out before entire length was lubricated. So along with the spring, a new cable will get ordered. Current cable works well enough to use for completing the foot lever project though. For now it is all back together and properly adjusted.
Definitely like the looks of the tall sidewall of the Block K on the 18" rim over the shorter sidewall of the Battlax 19" knobby tire. Totally subjective, but may sway the choice for the next sidecar tire.
Finally getting back around to working on the Screaming Yellow Zonker. Today was a simple project.
Plug welding, facing and drilling a new hole in an old clevis that had seen too many miles. Between the worn bolt and worn male clevis tab there was about 0.070" play. The thickness of the clevis tab was almost an 1/8" too thin, so there was no way to get proper torque on the assembly. Made for a very loose fit.
Plug welded the hole, then built up one face of the tab so it could be ground down to a nice tight fit. I like using copper as a backer when plug welding a hole. Does a good job of drawing excess heat away, and doesn't stick to the welding wire/rod.
After grinding and filing, all that was left was to drill a new hole, and reassemble with a new bolt.
A summer of hard off road use, and that was pretty much the only point of excess wear. SYZ is a darned good rig, and I'm fortunate to have it. 😎
Finally getting back to the sidecar brake project. Welded the clamp to the bracket plate today. Not much work, but forward progress is... forward progress. 🙂
Took a bit of time out from working on the broken down farm hobble to weigh the rig today. Just the rig with a full tank of fuel, empty panniers and the scissor jack in the trunk. 319 lbs 12 ozs on the front tire. 394 lbs 12 ozs on the rear tire. 189 lbs 6 ozs on the sidecar (no ballast weight). Just a touch over 904 lbs (give or take 2 lbs scale accuracy).
This bike alone was purported to weight about 536 lbs wet. Which means the sidecar, subframe and panniers makes up about 368 lbs. That is about 100 lbs more than I expected.
Scott, you said this is about 100 pounds more than you expected...
Did you check for any added items in the Sidecar, such as...a "almost" hidden STROOPWAFFLE that was shipped to you ?
Posted by: @miles-ladueScott, you said this is about 100 pounds more than you expected...
I'll bet that's it. BMW and Stroopwafel go together like Christmas and Markets. 🤩
It's funny, because SYZ pushes around in the garage much lighter. More like a svelte 902 lbs than the hefty 904lbs. Of course all the motorcycle reviewers note that the weight disappears once it is moving. 😉
The Screaming Yellow Zonker is getting an engine replacement. 😎
Finally found what I was looking for (unlike Bono of U2). 23K miles, 1995 (same year as SYZ). The only serious flaw with SYZ when purchased was the crack in the crankcase where the side stand mounts. The original builder used liquid steel to patch the crack. I bought the rig having been shown this flaw, and I've been looking for a replacement engine worthy of the rest of the rig since it came home.
Here is the flaw on the current engine, and because of the extreme off road work it has started leaking again. This will be a timely update for the '26 riding season.
Two ways to fix this rather common failure that I've read. Either Liquid Steel, or take it to a competent welder who is willing to try a repair. Here is what the area should look like (picture of this replacement engine).
The replacement engine will get cleaned up, new main, valve cover and front cover seals, spark plugs, cam chain tensioner upgrade and HES upgrade. before install. None of that will happen until things warm up late this spring. But at least I found the last needed piece. 😊
Say WHAT ????
Why not just install a Africa Twin engine in that frame ?
Or, better yet.... just buy my Africa Twin w/DCT sidecar rig.
I was going to do a Subaru swap. 😉
Africa Twin Adventure rig is the ultimate "easy button". 🤩 🤩 Sure hope you are going to take a bit of time to enjoy it before the sale. There are some stunning forest roads in your neck of the woods. Just waiting for an Africa Twin adventure outing. 😎
EDIT: I misread. I though you already were into this engine-changing chore. It will be quite a job, but worth it, I think
@scott-h You've certainly got it apart. I think BMW start building these around the engine.
I've got mine apart as well. Needed a clutch, is getting a newer M97 transmission and a 37/11 final drive. I'm also deleting the ABS.
Old and new clutch assemblies. Clutch disc was below minimum spec at 4.2 mm.
Replaced rear main seal, clutch release bearing and clutch release rod as it was bent?
My M94 transmission sounded like it had a handful of loose bearings when coasting, and has randomly slipped out of third gear at times.
I've got it mostly back together now.
Brian
- 5,479 Members
