Handlebar Oscillati...
Handlebar Oscillating or Wobble
124 Reactions
(@wahlbornwi-rr-com)
@ben-franklin The bike has a stock steering dampening mechanism possibly I need a better one or it is defective.  The set up measurements are
60 inch track width   -   152.4 cm
lean out 3 degrees   -    3%
toe in 1/8 inch   -   3.17 mm
sidecar wheel lead is roughly 10 inches.     -   250mm
Posted : August 29, 2026 4:14 am
 Arno
(@trespatas)
Posted by: @wahlbornwi-rr-com
Hi, thank you for your return; yes, the damper may have an issue, wobble would be normal in fact if you hadn't at the speed you mention.
Just one comment: 3 mm toe in, will make the setup very responsive, nervous, not a bad thing but will require all your attention.
PS: the damper should not be centered, must be engaged in the strait steering position, otherwise it will oscillate from on side to the other if at zero.
This post was modified 2 months ago 4 times by Arno
Posted : August 29, 2026 4:36 am
(@ben-franklin)
@wahlbornwi-rr-com , well as Arno mentions, that is not very much tow in, especially for a rig with a relatively wide track.
I would have expected about 5/8", but maybe if it did not pull to the right with 1/8" I would have left it there.
Depending how adventurous you are in toe-in adjustment, you might try increasing to maybe 1/2" and see how that goes.  I would expect some goofy handling with 1/8".
Posted : August 29, 2026 6:57 am
Brstr, Arno and FlyingMonkeys reacted
(@sidecarusa)
No you are correct they were at the time
Posted : August 29, 2026 7:03 am
 I am located in western Pennsylvania near Pittsburg
Will-I-Am, given that you are near Pittsburg, there is a sidecar gathering happening next month, that you are requested...requested I say...to attend.
The PenNy Hackers gathering is in CLARINGTON, Pennsylvania.
September 17-20, 2026
Timber Haus
Make your reservation at  https://thetimberhaus.com/
camp sites, cabins, and hotel rooms available
374 Shiloh Lane, Route 36
Clarington, PA 15828
814-646-7750
Call or Text
Join us for a casual get-together of sidecars and sidecar enthusiasts
near Cook Forest State Park
No sidecar? No problem! Come see why sidecars make people smile!
Join us around the campfire every night
Cookout on Saturday!
Questions?  MJ sidecarwitch@yahoo.com  724-316-8809
Posted : August 29, 2026 8:11 am
MJ reacted
(@panhead_kicker)
On an otherwise good handling rig, I developed a front-end wobble at lower speeds that my steering damper couldn't damp. Turned out my front tire had worn unevenly to one side, after several thousand miles. New tire, wobble gone. Probably not your issue since the sidehack is new to the bike, but worth understanding the possibilities.
Posted : August 29, 2026 10:43 am
Brstr, FlyingMonkeys, SIDECARUSA and 1 people reacted
 Arno
(@trespatas)
Posted by: @ben-franklin
@wahlbornwi-rr-com ,   I would expect some goofy handling with 1/8".
Hihihi.....yes, BUT it's so sharp.... basic_smile
Posted : August 29, 2026 2:15 pm
Brstr and Ben Franklin reacted
(@sidecarusa)
I would change many of those settings but hey if you like it then leave it.
The chassis is a dmc cx frame design from washington boss and clamp version. Relatively easy to adjust if you want more toe in adjust the rear heim joint out a few turns and see what that does for you.
Also from what I have heard  tsc is no longer authorized to be building those sidecars so yours was probably the last one made in the states. Watsonian squire usa will continue to sell the British made sidecars in the us with the original frame they were built on
This post was modified 2 months ago 3 times by SIDECARUSA
Posted : August 30, 2026 1:57 pm
@sidecarusa you mean I don’t have a Watsonian classis?
Posted : August 30, 2026 5:43 pm
(@sidecarusa)
Yes you just have the body and fender everything underneath is dmc sidecar metal works
Posted : August 31, 2026 9:58 am
Posted by: @sidecarusa
As Scooby Doo would say...
Rut Roh Scared
This post was modified 2 months ago by FlyingMonkeys
Posted : August 31, 2026 10:55 am
(@sidecarusa)
Its the dmc cx street frame you can tell by the rocker arm assembly and swingarm set up. Also its boss and clamp the watsonian frames are not and on the ones from watsonian in Britain the bumpers are part of the frame not bolted to the body So its somewhat of a hybrid car. Not talking trash but thats what you have
This post was modified 2 months ago by SIDECARUSA
Posted : August 31, 2026 11:08 am
Brstr, FlyingMonkeys and Arno reacted
@sidecarusa is DMC A good quality product?
Posted : August 31, 2026 4:07 pm
Oh, William,  you have opened the proverbial "Can 'o Worms".  Surprised
Posted : August 31, 2026 4:36 pm
Ben Franklin, Thane Lewis, Arno and 1 people reacted
(@ben-franklin)
@wahlbornwi-rr-com Well, mine was built along side yours, at the time...  DMC had a few issues towards the end of their run.  This thread captures my journey with them, at the time.  Jonny tried hard to fix the owner's bad decisions, but ultimately had to live with him until the end:  It got kind of ugly.
DMC Thread that evolved into my Africa Twin build:
Posted : August 31, 2026 7:05 pm
Page 2 / 4
