Finally got a sidec...
Finally got a sidecar for the Shovelhead
10 Users
 kmev
(@kmev)
Hello! After more than 20 years of dreaming, reading, and researching sidecars I finally acquired a Harley sidecar for my Shovelhead. I casually looked for many years for a year-appropriate 1972 with a fiberglass tub, but I am very happy with the purchase of an earlier 1960 metal-bodied car, which I think is much more classy (and few people will know the difference). Looking forward to getting it attached and unlearning 30+ years of two-wheeled riding.
Of course, there is always something to fix on a 40+ year old vehicle, so I'm taking care of a few of those things before the attachment commences. Hoping for a warmer Wisconsin winter than the last two years as I don't have the luxury of an insulated garage. Over the last several years I have spent a lot of time reading about sidecars here, but only now joined the forum. After the many years of reading, I am confident in my ability of getting the car properly set up, and equally confident in my inability to operate it once I get it on the road.
Posted : December 10, 2014 6:48 pm
(@trikebldr)
The heck with all the newer plastic cars,..... you got something much better, IMO, humble or not! That styling of that car is just iconic! Great find.
Posted : December 10, 2014 9:16 pm
(@oldschool_iscool)
Welcome to the slightly off-center world of sidecars!
As you have already found out, there is plenty of help on this forum. When you get 'er put together, take it slow. Read lots more about how to pilot a rig. Seems you already know that a rig and a solo cycle are two different animals.
Take a S/TEP class if you can. Get lots and lots of parking lot practice before you take to the open road. Load the car with about 70-100 pounds of ballast. NOTE: People are a poor choice for ballast while learning! Another tip, DO NOT call your spouse "ballast!"
Posted : December 11, 2014 5:43 am
(@hdrghack)
Exact combination that I started with in 1992,
If you are interested there is a company in Pennsylvania called L&W body they make all sorts of parts should you want to replace the wind screen on the sidecar.
Does the sidecar have brakes?
Posted : December 11, 2014 11:09 am
 kmev
(@kmev)
Yes, it does have brakes. It is quite complete, including the step that is not attached in the photo, the snubber strap and spring beneath the body, and all upholstery. I am aware of L&W, but to be honest, I much prefer the current windscreen over the original.
I am sure I will have a few questions as she comes together, and I do plan to read more on operation as she gets close to being road worthy.
Posted : December 11, 2014 7:14 pm
 kmev
(@kmev)
Where are these classes available?
I once took an advanced riders course on the old '72 because I was required to do so to ride on military posts. I found it helpful, but not aimed at riders of vintage mounts. I created a lot of sparks on that course.
Posted : December 11, 2014 7:20 pm
(@woodyambison)
Nice looking rig Keith. What kind is it ? Happy motoring!
Posted : December 14, 2014 1:57 pm
(@hdrghack)
kmev - 12/12/2014 12:14 AM
Yes, it does have brakes. It is quite complete, including the step that is not attached in the photo, the snubber strap and spring beneath the body, and all upholstery. I am aware of L&W, but to be honest, I much prefer the current windscreen over the original. I am sure I will have a few questions as she comes together, and I do plan to read more on operation as she gets close to being road worthy.
Did you get all of the mounting hardware to mount the sidecar to the bike with it?
Posted : December 14, 2014 2:49 pm
 kmev
(@kmev)
It's a 1960 Harley Davidson LE sidecar that I am mounting to a 1972 Harley Electra-glide. I did get all of the mounting hardware, although the rear mount was an unattractive home-made part that I am replacing with a Harley CLE mount. Originally, the LE's rear mount attached to the swingarm, which I don't imagine was the best for comfort or longevity of swingarm or bearings. The CLE mount, which was used on '78-up Harleys, mounts to the motorcycle frame rather than swingarm.
I also got an original Harley adjustable rake triple tree and steering dampner that I will install.
Posted : December 14, 2014 3:12 pm
(@hdrghack)
kmev,
A little tip, when it comes time to play with the points if you remove the bolts from the front mount between the springs the body will pivot up.
I used a bolt with a coupling that had a piece of round stock welded to it screwing it on the bolt I would install a small hook attached to a rope pull it up and tie it off you will have plenty of room to do any maintenance work
You will appreciate the adjustable trees....
Posted : December 14, 2014 3:27 pm
 kmev
(@kmev)
Ha! She hasn't had points or advance weights for a few years, now. That is a good tip to keep in mind though!
Any thoughts on the best gearing? My transmission has an Andrews close-ratio first gear, and the mainshaft tranny sprocket is one tooth larger than stock. The motor is stock displacement and compression with an S&S Super E carb. My riding will include both city and highway. I figured I would put a few miles on it before changing any gearing, but I'm hoping I could get away with the current gear ratios.
Posted : December 14, 2014 4:02 pm
Great find.
Posted : December 14, 2014 4:34 pm
(@oldschool_iscool)
Here ia a list of S/TEP training sites...
http://evergreenmotorcycletraining.org/sidecar-training/step-national-schedule-training-locations/
Posted : December 15, 2014 8:19 am
(@hdrghack)
kmev - 12/14/2014 9:02 PM Ha! She hasn't had points or advance weights for a few years, now. That is a good tip to keep in mind though! Any thoughts on the best gearing? My transmission has an Andrews close-ratio first gear, and the mainshaft tranny sprocket is one tooth larger than stock. The motor is stock displacement and compression with an S&S Super E carb. My riding will include both city and highway. I figured I would put a few miles on it before changing any gearing, but I'm hoping I could get away with the current gear ratios.
Well LOL never know may come in handy for other things...........The easiest and cheapest solution for me was to install a 54 tooth rear sprocket ran them for 20+ years like anything you will be down shifting just DONT let the motor lug!!!
Good luck kmev! keep us posted
Posted : December 15, 2014 12:54 pm
 kmev
(@kmev)
The nearest S/TEP course is in Urbana-Champaign - a bit far to be convenient, but I will keep checking the dates and keep it in mind.
My bike has a rear drum brake with a riveted sprocket that comes in one size only, so the cheapest and easiest for me would be to change the motor sprocket. I do need a new primary chain, so I will do a bit of riding with the rig to see how the current gearing works and then make a decision before I tear into the primary case.
Thanks for the help, folks! I am looking forward to this. Today, I got the adjustable triple trees cleaned, repaired, and ready to install. This will definitely keep me busy over the winter.
Posted : December 15, 2014 6:43 pm
