to hook up the S/C ...
to hook up the S/C brake??? ... or not??
20 Users
(@stancotreau)
HI, I have a 2009 Bonneville with a velorex S/Car on it. I have been happy with it, although I am still pretty new to this sidecar thing.
My rig came all set up, rides true and straight, stops very well without a brake on the S/Car. I can't help but wonder if I should hook up the sidecar brake?
If it stops well without it should I leave well enough alone .... or give in to my inner voice and hook up the brake? ...... any thoughts out there?
Posted : March 11, 2016 6:14 am
(@caddypat)
i would hook it up. i have ridden both ways and much prefer having the extra brake. if used properly there is no downside. pat
Posted : March 11, 2016 6:24 am
(@stancotreau)
thanks for the input
Posted : March 11, 2016 8:23 am
The mechanical drum brake isn't really compatible with hydraulic disc brakes. A few have hooked the Velorex brake up as a drag brake but the differences in efficiency make for erratic stopping capabilities at best.
Best use for the Velorex brake on a non mechanical brake bike is as a parking brake(required in some places).
Even disc braked sidecars have problems with straight line stopping without driver steering corrections due differences in swept volume of brake surfaces, sidecar loading, surface traction and direction of travel.
My professional opinion. Others, feel free to express yours.
Posted : March 11, 2016 9:17 am
(@stancotreau)
so, if I understand you correctly. In your opinion it'd be best to use it as an emergency brake, if at all.
my concern is just what you stated, disc / drum combo
thanks
Stan
Posted : March 11, 2016 9:20 am
Brakes on a sidecar are always a good idea, any one who say's that they are not usually has no clue as to how to hook up a brake and as such tells you that you do not need or want a brake on a sidecar. Any thing that might keep you out of an emergency room is a good idea. However the drum brake like much else on the Velorex leaves a lot to be desired. Why they keep selling a mechanical drum brake sidecar in an era when only a few bikes still have drum brakes on the rear gets down to the Velorex company is far more interested in sales then safety. If you want a brake on the sidecar to work well with the bikes hydraulic disk brakes you are either going to need to change the wheel to a disk brake wheel or change sidecars. If you do change wheels to a disk brake wheel chances are that the brake rotor will be to large to balance well with the bike. This is why we make our own cast iron brake rotors for our sidecars which every one either comes standard with a disk brake or the disk brake is an option as many people either can not get past looking at price or buy into the notion that a brake on a sidecar is not needed. I would not be with out one on my own rigs.
Posted : March 12, 2016 5:35 am
Jay,
The question was regarding hooking up the Velorex mechanical brake to be used in conjunction with the Bonnevilles' disc brakes.
In your opinion the Velorex brake isn't all that compatible with disc brakes. It sounds like you agree with me here.
I think the personal dis was quite inappropriate. I wasn't saying "Don't use sidecar brakes".
I feel they are worthwhile on a doublewide rig or one that is always heavily loaded.
In the last 26 years I have converted several URAL and Dnepr sidecars to disc brakes and linked the systems for clients, but do not use the sidecar brake on my personal rigs though several have had disc brakes, too many erratic stops.
I still had to countersteer in order to achieve a straight line stop. Due to the reasons stated in my earlier post.
I have used the two pedal system in past years for off road work with the mechanical sidecar brake pedal beside the rear bike brake pedal, with some success, but it takes a lot of practice to finesse this method.
Posted : March 12, 2016 11:14 am
 Sal
(@sal)
Not a professional here but having had a similar size bike and velorex I agree with Lonnie. Never felt the need for a sidecar brake, now if it would've been a heavier outfit then yes a brake would be helpful.
Posted : March 12, 2016 3:19 pm
(@al-olme)
OK, my two cents... I have rigs both with and without sidecar brakes and on balance I'd rather have a sidecar brake than not have the brake. With some few exceptions, if you have a sidecar brake, it should be connected. If for no other reason that it might help, even in some small way, in an emergency.
So what's the exception you ask? If the brake isn't working properly and causes too much brake pressure on the sidecar wheel. I've ridden rigs where the sidecar wheel pulled the rig sharply toward the sidecar under braking. Until that can be fixed, it is the only reason I can think for NOT wanting a sidecar brake. Even if the brake is ineffective it helps slow the rig. Sidecar brakes may not be essential but they are generally a good thing.
OK, now, make up your own mind ;~).
Posted : March 12, 2016 4:57 pm
(@stancotreau)
Thanks everyone, now I have to decide ...... it sounds like if I want to have a s/car brake I'd have to convert the velorex to disc...... any idea what that cost would be?
I appreciate you all taking time to answer
Stan
Posted : March 13, 2016 3:32 am
(@timo482)
still today lots of guys ride with no front brake on there bike - or never use the brake that is there, that is there business and ok for them. several of my good friends wear out rear brake pads regularly and have factory original front pads many many years in, that is there business and good for them. most of them most of the time do just fine.
keeping a lid on speed, not driving during rush hour, being super careful goes a long long way.
personally i want all the braking effort i can muster, i want all the wheels with the most brake i can afford. the typical moron driver pays zero attention to how far it takes me to stop and my bike has no airbag. in the harley manual it states that the rear brake pedal will make the rig pull to the right and the front brake will make it pull left & that minimum stoping distance is achived by using both at the same time - they are right.
most importantly in this discussion in the world of today - i would NEVER be caught printing in words or recorded voice telling anyone anywhere ever to operate on open roads with any brake on any vehicle disconnected unless i was old enough o be near done and had no dependents. i would also never ever tell anybody that I had a disconnected brake for fear of a insurance company investigator finding our about it. and if i do have a disconnected brake i want it to look like it happened this morning away from home and i was going home to fix it.
sorry for soap boxing and i hope you will all forgive me.
Posted : March 13, 2016 10:55 am
(@sidehackralf)
Over the years I've avoided hitting something, (deer, elk, people distracted for one reason or other). Last year Jay sent me the brake and everything to hook it up. On the first trip out a buck deer jumped over the barrier on a down hill grade. It was worth all the trouble right there because it stopped immediately and the buck brushed by the rig without contact. The braking balance is real good. I would recommend this setup to anyone.
Ralph
Posted : March 13, 2016 12:06 pm
Lonnie, No dis on you, Sorry you thought it was. Mainly there were two companies out their until very recently (one closed its doors, the other the owner died) that would tell you not to hook up brakes. One of the companies I even offered to provide them with every thing they needed for brakes on their sidecars. They were not interested.
I do however stand by my comments on the Velorex company. In a time where almost all bikes have disk brakes, why continue to build a drum brake sidecar? Safety must always come first. The only thing we offer for Velorex sidecars are mounts, nothing for the brakes.
Posted : March 14, 2016 6:05 am
(@Bob-Hunt)
Hi Stan. I don't begin to speak as an expert on sidecars but I've had a couple of them and one of them had the brakes on it which I quickly removed. I found that with the brake on it the s/c is gonna pull to the side and without it I could really get on the front brake until it squeals if necessary and she goes straight and true. I know a lot of people wont ride without brakes on the s/c but I just don't like them!
Posted : March 14, 2016 7:38 am
Your brake was not properly matched. It more then likely had far to large of a brake rotor.
Posted : March 14, 2016 7:41 am
Page 1 / 3
