Quote from
Big Tom on May 14, 2023, 9:25 am
I would like to remove it from my Yamaha and install it on my Goldwing.
I would take it back to Hannigan but 1603 Miles intervene.
Uploaded files:FlyingMonkeys has reacted to this post.
2009 Yamaha Venture with Hannigan Hack
1999 Valkyrie IS
2006 Goldwing
2021 Ram 3500/6.7HO
Quote from
Viajero on May 14, 2023, 9:43 am
Tom,Ā
Look on the main menu of the sidecar.com website, under "Sidecar Library" you will see the top menu item "Map of Sidecar Manufacturers, Dealer, and Installers". If you click on that you will see a Google Map, but that is a static image. If you click on it, it will open in a new tab to a Google Map of all places. From there you can zoom in on Arizona and you will see 3 places listed. Research those to see if they will fit your needs.Ā
Jerry
Webmaster
Tom,Ā
Jerry
Webmaster
"I ride because it frees my mind from the tyranny of petty things."
Quote from
Big Tom on May 14, 2023, 10:39 am
Thank you. I see three. I'll make some calls this week...
1999 Valkyrie IS
2006 Goldwing
2021 Ram 3500/6.7HO
Also, Tom, if you call Hannigan, and talk to either Stephanie, or Dave, or Corey, they can tell you the name of the shop in AZ that does installations of their Hannigan sidecars...for them. Might be a good source to use the same shop that Hannigan uses for installations in AZ.
Uploaded files:Big Tom has reacted to this post.
Two Million Miles, and All 7 Continents
Quote from
Big Tom on May 16, 2023, 3:24 pm
I spoke to Hannigan today and they have no installer in Arizona.
1999 Valkyrie IS
2006 Goldwing
2021 Ram 3500/6.7HO
