Ural sidecar mounte...
Ural sidecar mounted on Vstar 1100 classic
(@mayrel47)
Greetings, I've just purchased a 07' Vstar 1100 classic and a Ural sidecar. The sidecar was fitted to a R60/2 BMW with the ball/socket lower mounts(BMW has ball welded to frame). I spoke with Gary at Motorvation and he's sending me information/diagrams/photos of what I'll need to mount the sidecar to the bike. I researched several other mounting systems from other folks but wasn't impressed with their attitude and the quality of their hardware; Motorvation seems to have quality hardware and about the same price as their competitors.
With that said, has anyone mounted a Ural to a Vstar 1100 Classic and willing to share photos of your mounting system? One supplier refused to provide photos based on their fear their competitors or individuals would steal their designs. Purchasing expensive hardware "blind" doesn't appeal to me.
Specifically it looks like I'll need to have different brackets welded to the bottom tubes of the sidecar; I can get this done locally. Then it seems I'll need the correct sized hardware to set the sidecar up level with the bike. One main attachment is the front lower which needs to be adjustable for toe in/out. The rear bottom and two upper mounts shouldn't be too difficult.
Most instructions explain the distance between the rear bike axle and sidecar axle should be between 8 and 10 inches, with the sidecar wheel forward of the rear bike axle.
I've had other sidecar rigs, one I mounted myself(Velorex 562)which came with "universal" mounting hardware. It worked OK. I also had Bob Darden mount a Texas Standard on a R80/7 BMW which was perfect. The other rig was a Ural-T. We liked the Ural sidecar size, but performance was limited with the bike. After seeing the improvements to the new Urals they've done a good job, but the least expensive model Ct is over $13,000 new. I decided to put one together myself; the Vstar 1100 has plenty of performance and is suitable for mounting a sidecar relatively easy. We were able to find the bike and sidecar for significantly less money, both in excellent condition; I will have about $7500 invested when the rig is complete.
Any detailed information from you "experts" who have put together their own rigs, specifically a Vstar 1100 Classic and Ural sidecar will be greatly appreciated. Early thanks, John You can email me direct if desired mayrel47@cox.net. We're located in Navarre FL 32566, northwest FL.
Posted : October 8, 2016 6:24 am
(@mayrel47)
Obviously there are several ways to attach the mounts to the bike, and the sidecar. If you don't mind, I'd like to see photos of your mounts. You can email me direct if you like; mayrel47@cox.net
We're located in Navarre FL.
I agree, Gary and I talked for some time; I'm convinced he is the best supplier and has experience. His prices are competitive with other suppliers, but his "can do" attitude and willingness to share information is top drawer.
Most bikes with box frames are fairly easy to attach mounts. I hadn't thought about where the frame is bolted together for engine removal; this may well be an option I can use?
I should have the bike and sidecar in my garage within the next couple three weeks. The first step is to get them sitting side by side, both level. Then we can determine positioning; 8 to 10 inches from the bike axle to the sidecar axle, sidecar axle forward. This will determine where the lower mounting tubes need to be fitted to the bike. Next we'll need to see how the mounts need to be configured to clear the bike mufflers and floor boards. The upper mounts should be easiest; front top of bike frame and somewhere as high as possible around the aft section of the seat.
The sidecar comes with the two upper struts, but I think I'll replace them and get everything from Gary. I'll be able to send him measurements and photos so he can determine the best mounting solution.
I know some can fabricate their own mounts or take their design/measurements to a local fabricator, but peace of mind is worth something, and obtaining mounts from an experienced supplier just makes sense.
Again, early thanks for your response. John
Posted : October 8, 2016 8:43 am
(@mayrel47)
I agree Dave, if you have the tools and basic sidecar mounting instructions(available on line)the mounting brackets could be fabricated. The struts and clevis mounts are worth the money to purchase. As I've mentioned, once I get the bike and sidecar lined up I will be able to determine exactly what's needed. I like Motorvation's quality hardware so I'll purchase from them, and I like Gary's willingness to assist me long distance. We'll see what he suggests; apparently they have kits available or can fabricate them if needed. The Ural sidecar I purchased has two straight tubes for the bottom mounts, each have the ball/socket attachment(female socket on the sidecar). This sidecar was mounted to an older R60/2 which has the ball mounts welded to the bike frame. I'd prefer to bolt things on the frame as welding can weaken the tubing. This shouldn't be a difficult project with the correct hardware. Alignment of the sidecar axle to bike rear axle will determine if we will need to do some welding to the sidecar mounts. I'm hoping I can use pinch bolt brackets for the two bottom tubes with the appropriate angle for attaching hardware to the bike; mainly clearing the exhaust system and floor boards/brake. I may be able to use longer bolts for the mounts on the frame; the frame can be unbolted for engine removal. Right now I don't have the bike or the sidecar, should have the bike next week, the sidecar the following week, then we'll go to work. I appreciate your comments. I'll put together a detailed photo/instructions as I proceed, to include the wiring for lights on the sidecar. I'm somewhat color blind, but my wife can help me with this. I'm not sure how to post photos on this site, but I will make them available via email.
Posted : October 9, 2016 12:39 pm
(@michaelh)
I'm surprised that neither Jay nor Claude have weighed in here. Since we own a Vstar 1100 Custom with a DMC Kenna double, I'll throw in my USD 0.02. If there's an 'attitude' issue from either of them, I'm going to go out on a limb and say that they're just finishing off their busy season, and will have a lot more time to chew the fat in a month or so. Jay's also recovering from a medical procedure as well. My impression of the sidecar biz is that it's like the old joke, 'how do you make a small fortune? Start with a large one'.
Both of them (who have forgotten more about rigs than I've known) have said that sometimes they've used sub-frames on the bike, sometimes not. When Jay did ours, it must have been one of those 'not' times 🙂 He picked up three points on the bike to create attachment points, then used a clamp for the rear lower.
I'm a bit wary of the clamp, but I put a witness mark on it, and after a couple of years on our roads (in places, 'road' is an overstatement!) it hasn't moved.
On the front, for the upper, he welded a boss to #14 on the frame IPL, lower to the rear brake bracket.
For the upper rear, he went into the 'curvey part' of the arm that support the rear fender/pillion seat (the part that gets cut off when you have a bobber type fender).
Like I said, all seems to work ok to me.
Another Vstar 1100 Custom owner has a 'reinforced' Velorex, has serious miles on the rig, and she has the frame clamps that came with the Velorex.
Posted : October 16, 2016 9:56 am
(@mayrel47)
I'm not willing to reveal who I was referring to. My decision to go with Motorvation was primarily based on the quality of their hardware and their willingness to send me detailed photos and diagrams of the mounting system for my particular application. Additionally the price of the hardware was very close to the same. However, I'm mounting a Ural sidecar which is much heavier than the Velorex; I was concerned about the hardware being strong enough. I'm sure these other suppliers have good hardware with much success or they wouldn't remain in business. So I can't speak about their products reliability or their reputation.
I have had other sidecar rigs and didn't have any issues. I too used the hardware that came with the Velorex 562 which I purchased new. The other rigs I had were done by professionals; Texas Standard on an R80/7 and a Russian Denper on a R100GS. I chose the Vstar 1100 based primarily on dealer support in our area: I got a good price for an 07' with only 11,000 miles and unmolested with aftermarket exhaust systems. I was also lucky to find a Ural sidecar in very good condition for a great price(although I have to drive some 30 hours to bring it home). All in all I'm pleased with what we'll have for a reliable sidecar rig for under $8000 ready to roll.
We live in Navarre FL in the panhandle, mostly flat and straight roads. I haven't seen but a couple of sidecar rigs which I think were tourist traveling through and one Ural Gearup which is for sale. There are mostly HD and metric cruisers. The Vstar 1100 we have should provide adequate performance with the Ural sidecar, enough to ride at the legal speed limits on highway and secondary roads. Having owned a Ural-T, which we thoroughly enjoyed, the only issue was it's limited performance and braking, and more frequent routine maintenance. With that said, the newer Ural's have been significantly improved with fuel injection and disc brakes, although maintenance is still required more frequently. If you can live with the slower pace and can perform your own maintenance, the Ural is a very well designed sidecar rig which offers off road use. Dealerships are not always nearby, but I can testify their customer service is superb. The Ural Ct is reasonably priced at $13,000 new, if you're looking for a sidecar specific designed rig, there isn't anything in it's class. I decided to put together another sidecar rig which is less expensive and achieves our objective for local riding and touring. We opted to trailer our Ural long distances, now we can tour on the rig.
I appreciate all the responses to my initial post. When we begin mounting the sidecar I will have detailed photos available to show the step by step process. John
Posted : October 16, 2016 3:55 pm
(@michaelh)
Hi John,
Please keep in touch, I'd like to hear how your adventures go. Most people have their cars mounted to BMW or H-Ds, we're somewhat in the minority, so it'd be nice to exchange notes.
best,
Michael
Posted : October 17, 2016 11:16 am
(@mayrel47)
Hello Micheal, just got home with the hack, bike is still in the shop, so I'm unable to do anything. I will keep you posted. Maybe we should go to PM correspondence and/or email? There may be some things only interesting to us? John
Posted : October 20, 2016 11:40 am
(@al-olme)
While I'm a fan of PMs for buying and selling, I urge you to leave your mounting discussion on the public side. It will undoubtedly be of value to someone in the future. Thanks.
Posted : October 20, 2016 12:18 pm
(@michaelh)
I'm cool either way John, I'll pm you my email in case there's something you want to chat about off board.
Please understand that my knowledge and experience is only based on the one rig.
Posted : October 20, 2016 7:10 pm
(@mayrel47)
Hey Michael, I guess we should share our discussions with other forum viewers;never know what might come of it? Looks like I'm going to have to do some modifications to the Ural bottom front mount, and possibly the rear bottom as well. They are the ball/socket type mounts which fit perfectly to the R60 it was mounted to. I'm waiting for my bike to get out of the shop to determine what needs to be done. I'll send photos of these mounts to Gary at Motorvation to get his input. The rear bottom mount is a tube held in place via pinch bolts, so it could be completely removed and replaced, or modified. The front bottom mount is part of the sidecar frame, so it's not as easy to deal with; it has an angle to it. As you know the front bottom mount needs to be adjustable for toe in/out. I'm confident this will all come together, just need the right mounting brackets and/or some welding. I'll send you photos via your email as I don't know how to post photos on this forum. Later...John
Posted : October 21, 2016 3:56 am
(@IndSlim)
Oops........... double post.
Posted : October 21, 2016 5:02 am
(@IndSlim)
To post a pic, write your post, then check the box at the bottom that says "attach a file after posting". Click on "attach a file" and choose one from your computer.
Posted : October 21, 2016 5:13 am
(@mayrel47)
Thanks! I'm not the most computer smart old guy out there....age thing I guess...John
Posted : October 21, 2016 10:06 am
(@mayrel47)
I recently spoke with Gary at Motorvation. The Ural sidecar I have was originally fitted to a R60 BMW using the ball and socket(ball joint) lower mounts. With the 19" wheel the sidecar frame is about 12 1/2" off the ground. Gary suggested cutting off the protruding 2" tubing on the lower mounts and welding a section of square tubing to the bottom of the remaining frame. The idea is to get the bottom mounts of the sidecar as level as possible to the lower mounts on the bike. This will require some aligning of the upper and lower mounts to achieve a straight line from the bike frame to the sidecar(90 degrees vertically).Once this is accomplished aligning the sidecar to the bike will be simple; keeping a distance between the bike axle and sidecar axle 8 to 10 inches forward of the bike axle, then marking where the mounts will be attached to the sidecar frame in line with the mounts on the bike frame. The challenge is to determine the size of the square tubing to use on the sidecar. Once I get the bike home I can determine how far down I need to come to be level with the bike frame. I suspect this will be about a 6 to 7 inch difference. This can be accomplished using slider pinch tubes on the sidecar attached to a 2x2 square tube welding to the bottom of the existing frame and clevis tube in the length needed. I'm going to try and keep these at 90 degree angles using a slanted slider pinch tube connection which Gary has. I should need two sets of these and the correct length struts for the upper and lower connections. I will ask Gary if it might be best to use a larger square section of tubing on the sidecar to reduce the length of the slider/clevis tubes. As I mentioned before, I will attempt to provide photos on this forum. I just attempted to add some photos as a test. Apparently my iMac won't talk to this mircrosoft forum? If you want photos, send me your email and I'll include them. Maybe I can send photos using this forums PM function?
Posted : October 27, 2016 3:34 pm
(@al-olme)
mayrel47 - 10/27/2016 7:34 PM
<>As I mentioned before, I will attempt to provide photos on this forum. I just attempted to add some photos as a test. Apparently my iMac won't talk to this mircrosoft forum? If you want photos, send me your email and I'll include them. Maybe I can send photos using this forums PM function?
This isn't a "Microsoft" forum so if you're having trouble posting pictures, maybe we can help. The PM system doesn't support photos.
Posted : October 27, 2016 4:09 pm
