Steering Stabilizer...
Steering Stabilizer?
 46u
(@46u)
Sidcar - 12/2/2012 7:33 PM
A steering damper for a VW Beetle, the original Beetle that is, is a popular choice and should be easily available.
Sid
That is what came on on a Harley sidecar from the factory. I was told you can pick them up new for about $20.
Posted : December 2, 2012 1:41 pm
Just looked at some, 20 bucks to 60 depending on maker. Thanks
Posted : December 2, 2012 1:47 pm
(@Sidcar)
Now there you have me. I've never had to fit one and although I've seen outfits with them on I never asked what fittings were used.
Have a look at this it might be of use.
http://www.sidestrider.com/steering.htm
Sid
Posted : December 2, 2012 1:52 pm
 46u
(@46u)
That one looks very similar to mine.
Photobucket
Posted : December 2, 2012 2:11 pm
We have found on the Bonneville as long as you have good solid mounts, no flex in the sidecar or its mounts that a damper is not needed if the alignment is correct. None of the many Bonnevilles we have mounted our M72D sidecars to has needed one. We also make a new from billet triple tree that we usualy run that moves the front wheel forward making for lighter steering, while this will not make a front end shake go away it does make it a lot easier to deal with.
Before I would run a damper on this I would make sure that your mounts are solid, then try changing the toe in setting 1/8 of an inch either way. You may find that you do not need a damper at all.
Posted : December 3, 2012 6:44 am
The Bonnys and Guzzis don't seem to have excessive trail like most of the Japanese cruisers and many Beemers. We've never had to use an aftermarket damper on either.
With a sidecar as light as a Cozy and a new Bonny the only thing I can think to do is proper alignment and perhaps snugging down the neck bearings so the front end doesn't just flop from side to side.
Posted : December 3, 2012 9:30 am
jaydmc - 12/3/2012 11:44 AM
Jay G, Ordered a triple tree for the Bonneville last week from you. The installer put the stabilizer that came with the car on the bike. Never tried it with out it.
Posted : December 3, 2012 11:04 am
 46u
(@46u)
jaydmc - 12/3/2012 12:44 PM
He is talking about the raked trees many of us have told you about. Some trees can be modified and some cannot. On my Harley they cannot be so if I want raked tress I have to buy a hole new set which is not cheap for a person trying to live off $600 a month like I am and that is on a good month. LOL 😉
Posted : December 3, 2012 11:07 am
That is what I ordered, a raked tree from DMC. Saved my pennies and sold a rifle to buy it. I know what you mean on the money, have my 25 years in at the prison and can retire but can't afforf to live on the 1/2 pay right now.
Posted : December 3, 2012 12:19 pm
