raked trees and dam...
raked trees and damper
Is anyone running raked trees and a steering damper both? Or is this overkill?
Posted : January 15, 2011 4:13 pm
It is never over kill to put a damper on sidecar steering. I have at least one friend who spent about 6 months recovering from a crash that in my opinion might never have happened with a damper.
Ten sidecar rigs and 45 years experience goes into my opinion.
My opinion also says friction dampers suck. Hydraulic is best.
Phelonius
Posted : January 15, 2011 6:36 pm
I prefer no damper unless rig headshake is uncontrollable. Slower steering, steering resistance and loss of road feedback comes with the damper.
Some claim hands off riding OK with one. I say BS on that. Keep at least one hand on the bars at all times with a sidehack.
Posted : January 16, 2011 5:17 am
Phelonius - can you tell us a little more about the rig your friend had the accident with? Do you know if his front end was stock?
Daryl
Posted : January 16, 2011 9:27 am
I'm with Lonnie. I've had them on all of my bikes except the Valkyrie and always took them off after a while. I prefer to fix the problem instead of cover it up.
Posted : January 16, 2011 9:30 am
(@timo482)
harley flt chassis are subject to head shake [from 84 to present, the pre 84 frame is not a issue]
for solo use there is a fairly delicate and complicated procedure to adjust the head bearings to get enough resistance to lower the risk of head shake.
but for sidecars they used a friction damper in the pre 84 units - i think as a option - and a optional factory raked tree - and a optional 3 speed with reverse trans - hand shift and foot shift. however pre 84 units really could not run over 60 something for any length of time so it was not a issue.
since there are MANY theories why the flt frame can suffer head shake, but no "for sure" solutions & the factory puts a dampner on all the sidecars, specifically to address head shake - im leaving mine on.
some texts refer to it as "tank slap" search for the two terms and you will find a LOT of noise about it - its nasty - and occasionally fatal.
it appears that rear tire condition and inflation can affect it, as well as the rubber engine mounts & the ball joint links. whatever the reason for it on flt frames its nothing to mess with & checking bearings every 5 or 10k [wheel bearings and head bearings] may help.
Posted : January 16, 2011 9:52 am
 VLAD
(@vlad)
After i install Power Trak I see no need for any damper. I think Power Trak is best modification i did for my rig. Do raked tree, try it and then if you feel you need it you can do damper. Most likely you will not need it.
Posted : January 17, 2011 4:58 am
Played with the lean .....she now tracks straight while going down the road......put almost 200 miles on here today.........
Posted : February 13, 2011 1:01 pm
(@SideCar)
My progression for my Valkyrie and double wide Texas Sidecar was
- Sidecar - no steering mods so I could see how the unmodified steering was (had some headshake at low speed, but not horrible)
- 1 year later - Added modified triple trees by SideEffects (big help on steering effort and reduced headshake)
- 2 years later - Added hydraulic dampner to see what it would do for low speed headshake/shimmy
- End result - easier steering than before the triple trees (but not as easy as without the dampner) and no discernable shimmy.
I'm really pleased with the results
Posted : February 13, 2011 3:09 pm
Nice to hear. I sprung for Side Effects Steerite modified triple tree for my GL1100. Not installed yet. Looking foward to trying 'em out.
Posted : February 13, 2011 3:30 pm
