Lineing up GL1500 a...
Lineing up GL1500 altenator? Do i need new cuss words
40 Reactions
Steve Ives
(@none)
So i have my new alternator in place but i am struggling to line it up. New rubber spacers fitted to engine, dowels removed, o ring oiled.
Is there a knack to it or just pure dumb luck. Had enough today with other stuff time for coffee and rest
Walk with Joy
Steve Ives
Posted : June 1, 2024 3:41 pm
Steve,  for  most it is just plain  luck.
But.....a helpful  trick is to lube those new rubber spacers with a SilGlide, or silicone,  or any  grease, so that the  metal  of the  new alternator can easily slide into the  groves between the  rubber  spacers.
Posted : June 1, 2024 5:15 pm
Steve Ives reacted
YouTube is your friend.  Just fast forward to the part you need to see.
Tutorial - Honda Goldwing GL1500 Alternator Replacement How To
GL1500 alternator replacement
Part 1 --
Part 2 --
Goldwing GL 1500 Compu Fire alternator fitting
Replacing the alternator on my '94 Honda Goldwing gl1500se part 1 of 3
Posted : June 1, 2024 5:22 pm
Steve Ives
(@none)
Got it. So i will go outside in the morning fresh as a daisy and the Alt will simply fall in to place. Watch this space =)
Walk with Joy
Steve Ives
Posted : June 1, 2024 5:37 pm
The REAL sign of maturity is knowing when to walk away from a frustration and when to return.
Yeah, I'm still learning that...
Posted : June 1, 2024 6:04 pm
Steve Ives
(@none)
@thane-lewis Complete with LOTS of stupid along the way =)
Walk with Joy
Steve Ives
Posted : June 1, 2024 6:06 pm
Steve Ives
(@none)
Its in!!! nice dose of morning fresh brain, once i realized that the casting of the middle bolt lines up perfectly with the slot in the rubber it was much easier. Wing starts and shows13.82 on tick over and the battery stayed fully charged all the time it was disconnected.
Walk with Joy
Steve Ives
Posted : June 2, 2024 11:56 am
Ben Franklin, Thane Lewis, FlyingMonkeys and 1 people reacted
Can't argue with 13.8!  Now, you still gonna try to go to the Rally?  Without the triple trees, might be a good idea to drive.  In a car. Nobody would fault you.
Posted : June 2, 2024 1:07 pm
Posted by: @none
Steve,  did you  lube up the  rubber  spacers like  I  suggested,  or....shove it  in there Bone Dry ?
My opinion.....button  up everything  that  was involved with the  electrical  issue, get a couple  good nights  sleep,  then take  2 days to pilot  that rig to the  Sidecar  Rally.
Oh, and  CONGRATS  on solving the  primary issue,  replacing the  alternator, and learning  so much  in the  process.  clap
Posted : June 2, 2024 1:49 pm
Steve Ives
(@none)
Yeah but that does not feel right. If i can ride 250+ with a naprostomy tube in my kidney and a catheter up my winkle i should be ok if i take my time. Very likely leave here Tuesday
Walk with Joy
Steve Ives
Posted : June 2, 2024 1:51 pm
Thane Lewis reacted
Steve Ives
(@none)
Miles. no got some grease and oiled the o ring etc. I had already dipped the rubbers in clean motor oil the day before. I have no intention of doing it in one go for sure. I can keep going, will the wing =)
Walk with Joy
Steve Ives
Posted : June 2, 2024 1:54 pm
Yes, the 1500 Wing will  live...longer than  most of us.  You have  just  replaced  one of the  very  few Achilles  Tendons  of that  bike.  The new alternator will  last another  100,000 miles.
Posted : June 2, 2024 1:59 pm
Steve Ives
(@none)
Miles i am laughing my head off here i was born with both my Achilles tendons messed up!!!
Walk with Joy
Steve Ives
Posted : June 2, 2024 2:02 pm
DRONE and FlyingMonkeys reacted
(@varn-cummings)
Steve, congratulations on your doing the job on the wing.   I’m looking forward to seeing you and my old bike @ the rallye.  I’m also leaving Tuesday.    I  once had a 1988 gl1500 and the alternator finally died while I was up in Newfoundland.  That was back in 1998.  Talk about a deserted place to get help!   But a great guy at a little mechanic shop ( for cars & trucks) tore into it and found a bushing in the rear housing had worn till the armature was making contact w/ the stator.  I was fortunate in that all it needed was to get a new bronze bushing in the housing and he had one that was for a starter motor that he machined down on his little lathe.     Later on in that same trip I crashed on a wet slippery wooden bridge up in Labrador.  It tore up the bike pretty good but I was able to duck tape & baling wire it back together and about 3 weeks later made it home.  I lived in Savannah Ga back in those days.  Ins. Co. totaled the bike & let me keep it.  I bought a 1998 gl1500.  So I had been told that the early 1500s were notorious for alternators giving up pre-maturely. ( between 35k to about 70k.) mine was at about 50+k.   Also, my 2004 1800 alternator let go about a year ago near Cleveland Tenn. ( on a Sunday nite of all times).  ( most M/C shops are closed on Monday).  Ended up having to get a roll back to carry me to Hendersonville NC. (1200.00 tow bill).( M/cycle w/ sidecar towing lee-sur-lite camper trailer).    Schroders Honda overnite a new alternator and had me going by Wednesday. So why do we do this stuff???   I think we are a little touched basic_smile Head Explody
Posted : June 2, 2024 3:39 pm
MGV8 and FlyingMonkeys reacted
@none Steve, PM me with your route plan.  We plan to leave Tuesday from Central Nebraska and will likely overnight in Willow Springs MO.  Looks like a fairly easy day 2 to Iuka from there if you want to meet up and have a tailgunner.
Posted : June 2, 2024 4:03 pm
FlyingMonkeys and DRONE reacted
