Harley Mounts Quest...
Harley Mounts Question
(@Korny)
Help!
Does anyone know if the mounts would be the same for a 1999 FLHTCUI (Ultra Classic) and a 2002 FLHR (Road King)?
Got a chance to add a car to the Ultra and if mounts would be compatible, will probably do it.
Thanks for your help.
Posted : September 22, 2015 10:25 am
(@davet)
What year is the sidecar? There are a few differences in the lower mounts depending on how old the sidecar is but if it is currently attached to the 2002, it should fit the 1999. Attached is a set of installation instructions and a picture of my lower mounts from a 1996 TLE. The newer rear mount has two bolts instead of three, and the newer front lower mount only attaches to the right front down tube, but the older mounts will work on your 1999. If your frame has the hex fitting shown in the second picture, you can use the older rear mount. It is just rearward of the right passenger footboard.
-J03263.pdf (1.3 MB)
Posted : September 22, 2015 12:24 pm
(@davet)
Here is another set of installation instructions, this one or the one from my previous reply should be what you need.
-J00803.pdf (2.8 MB)
Posted : September 22, 2015 12:41 pm
(@Korny)
Thanks for the information!
Posted : September 22, 2015 1:39 pm
