CSC FIII tire
4 Reactions
need to ask if anyone has used a 155 70 or 65 R 13 on their F3 car. it comes with a 145R13 that is equivalent to a 145 80R
I am having trouble finding the 145 but really need or want a shorter tire anyway. I feel pretty confident the 155 65 or 70 will fit and lower the car just a little but wanted to see if anyone has tried it before. If not I may be the gunnie
Posted : April 17, 2024 2:55 am
(@smitty901)
Your call.
Posted : April 17, 2024 3:12 am
Ace--never had a Friendship III so no personal experience.  Looking at the numbers, though, I agree that either the 155/70-13 or the 155/65-13 will fit the rim OK and should give you a good solid bead lock (the 70, better).  The only question in my mind, though, is if you'll have enough clearance between the tire and the FIII fender.  However, the answer won't cost you much.  You can buy a 155/70-13 tire at Walmart for under $50 [LINK] plus the cost of mounting. If it rubs, you can start over, or try some mods to make it stop rubbing like a wheel spacer to push the tire away from the inner fender, or a belt sander to change the contour of the outer fender. :D
Posted : April 17, 2024 10:07 am
My FS3 came with 155/80 R13, I am thinking of changing for a 155/70 R13, to lower a little bit the car (in S, T speed rating) lots of choice!!
Pic of my stock tire...
Posted : April 17, 2024 10:20 am
(@smitty901)
 Dropping to a 12 inch wheel is also an option. Tires with speed rating of 118 are common. That is what I run on the Twin classic.
As for fit as a general rule staying with in 3% fits when swapping wheel sizes.  Get to 6% highly questionable .
Posted : April 18, 2024 6:11 am
good to hear the 155 will fit, might consider it next time. I went out to the rig and found I had plenty of clearance in the fender but was leary of the clearance to the shock so I went ahead and got another 145 FS F560 like I have on it now.
Posted : April 18, 2024 7:41 am
(@kevin)
Quote from smitty901 on April 17, 2024, 8:12 am
Your call.
smitty, where did this tire measuring thing come from? i change tires on a number of old bikes with obsolete specs and im interested in this.
Posted : April 18, 2024 1:58 pm
I decided that a 155/65 R13 would be ok: lowering a little the car should be good for the GW (and the general look!!); I can live with the differences from my stock 155/80! Now if I could find this wheel !! (I contacted AlliedWheel (original seller) but still no answer).
Posted : April 19, 2024 5:12 am
(@smitty901)
 Post a picture of the wheel
Posted : April 19, 2024 6:49 am
It is the one posted above on the HD/Hitchaker with the 4 lugs. Found this other pic @Florida Sidecars:
https://florida-sidecar-products.com/pages/hitchhiker-sidecar-history
Posted : April 19, 2024 7:17 am
(@smitty901)
     I could not figure out the one your are talking about fro the pictures on that page.
Most of those type wheels were from other products like small foreign cars or trailers. .
Amazon shows many
https://www.amazon.com/13-inch-rims-4-lug-Automotive/s?k=13+inch+rims+4+lug&rh=n%3A15684181
E Trailer
https://www.etrailer.com/Trailer-Tires-and-Wheels/Dexstar/AM20242.html
Posted : April 19, 2024 3:28 pm
This is the only ref I found about this wheel:
Posted : April 19, 2024 5:40 pm
(@smitty901)
Allied does not offer a 13 inch 4 lug any more.  Most used ones you can bet have been scraped. Again Wheels were not made for the sidecars. They  came from other sources as needed. Sadly  steel wheels did not last long as swap meet parts they ended up in scrap.
Posted : April 20, 2024 12:54 am
I saw that in their online catalogue… did not even have the minimum courtesy to answer my email request…
Posted : April 20, 2024 4:27 am
(@smitty901)
Most likely the people that work there did not have a clue.   They need list of year make model engine trans and how many doors.
may even ask the vin to buy a lug nut now days.
Posted : April 20, 2024 8:23 am
