2001 V-Max with Stock Front End
Does anybody have a V-Max with stock front forks (43mm) that pulls a sidecar? If yes, I would appreciate finding out what fork leg springs (heavy duty from Progressive Suspension?), type of oil and air pressure you use. I am asking because my front end still feels a little soft even if I use Progressive heavy duty fork springs. By the way, my triple tree has "Steerite" modification.
Piero Bassi, Minneapolis, Minnesota
Use HD or racing oil in the front forks and keep the air at maximum factory setting.
I am assuming that HD stands for Harley Davidson and....thank you for your suggestion!
If using Harley oil it would be "Screamin' Eagle" label. Others list Heavy Duty usage (HD).
Piero,
Hi! from Tacoma. I am anxious to see your new project when it's completed.
- 93.4 K Posts
- 2 Online
- 5,439 Members
