2001 Suzuki Intrude...
2001 Suzuki Intruder 1500 LC and sidecar options.. Help appreciated.
(@Kramer765)
We have a 2001 Suzuki Intruder 1500 LC and were looking at getting a sidecar (prefer a 2 seater) How well is this bike suited for a sidecar?? Does it need any fork work or anything else to manage it?? Anyone know the mounting points? Thanks
Posted : April 19, 2006 10:53 am
I like the retro look of the 1500. I think it would be great with a sidecar.
Posted : April 19, 2006 11:08 am
Your bike will work fine with a sidecar. Sidecar mounting points are easily accessable. For a double wide I would consider raked triple trees to overcome the heavy steering due to excessive rake and trail of (most) Japanese cruisers.
The rear shocks will also need upgrading (even if new). Use a heavier viscosity fork oil and you should be good to go hackin'.
Posted : April 19, 2006 2:02 pm
(@Kramer765)
So what is the cost of new rear shocks and upgrading the front end??
Posted : April 19, 2006 2:20 pm
Check with the vendors.
Progressive Suspension about the shocks.
Perhaps Side Effects about modified trees.
Unit has the leading links.
Easiest way is to search for dealers on the net and compare prices.
Posted : April 19, 2006 7:11 pm
Kramer,
These mids will certainly make things better for your rig and you but you can work up to them if you don't want to shell out the bucks initially. This is one of the nice things about sidecars, most are a work in progress.
Posted : April 19, 2006 11:58 pm
(@Kramer765)
Claude Thanks for reply as i was getting shell shocked thinking i was not going to do this because i thought i needed it all right away!! Thanks.
Posted : April 20, 2006 5:11 am
We make a mounting kit for this bike, It is one of the simplest bikes to mount a sidecar to. Our Double Kenna is the least expensive two seat sidecar on the market. With mounts for your bike it is $3495
Jay Giese
Dauntless Motors Corporation
www.mysidecar.com
Posted : April 20, 2006 5:55 pm
