auxiliary gas tank ...
auxiliary gas tank for sidecar rig
(@hankhallmark)
Thanks for the information.
Does it take up the entire tour pak?
hank
Posted : February 9, 2009 2:51 pm
Yes, but their is a little room around the tank and I leave the space unabstructed. If the tank is mounted below main tank level you will need a fule pump if you have carbs. Its not a bad arrangement. It works for me.
Posted : February 10, 2009 4:37 pm
The nicest auxilliary tank I have seen was in between the sidecar frame filling up all the space below the boat. Equiped with an ordenary car gasoline pump the rider not even had to flip a valve for refill on the ride.
Sven Peter
Posted : February 10, 2009 4:41 pm
