auxiliary gas tank ...
auxiliary gas tank for sidecar rig
(@hankhallmark)
I heard that Champion sidecars had installed an auxiliary gas tank in the right side bag of a sidecar rig. Upon checking they stated they no longer install these tanks.
In order for me to maintain/increase my range I an interested in installing an auxiliary tank.
Does anyone have experience with this subject and/or can they recommend a vendor.
Posted : August 3, 2007 6:49 am
(@sebjones)
Without getting too crazy with instalations which feed the main tank, and there are a zillion ways to do that, may I suggest ........
have any welder build you a tank to fit whatever space you have available, attach a fuel pump, an on/off switch, a long hose and you are the traveling gas station. It works well on my rig and adds ballast. It also makes you a hero when your buddies run out of gas, to say nothing of the ability to fill up the lawn mower.
Posted : August 3, 2007 7:04 am
Hey Hank, I notice you live in Wrightwood? We have a weekend place there, go every week when in town (actually I ride up often during the week, love riding Angeles Crest). Perhaps we could hook up?
I have an auxiliary tank on my GoldWing, as well as an Auxilliary can on my Suzuki/Ural rig. Could show you both. I am in Canada as i type this, on out way to ALaska. Will be home in 3 weeks or so.
my direct e mail is gregkbenner@yahoo.com
greg
Posted : August 3, 2007 7:46 am
Hi Hank, Google Tour tank. It's worked well for me for 3 years now.
David
Posted : August 3, 2007 5:21 pm
I'd be more inclined if I were installing an auxilliary tank to get a fuel cell. Summit Racing has all sizes and shapes and you can get a cell with anti-slosh baffles in a variety of filler cap configurations. They even have demand pumps and AN fitted stainless fuel lines and fuel line QD fittings. Gasoline, especially warm gasoline is extremely volitale. Caution must be excercised or you might turn into a flaming projectile.
Posted : August 3, 2007 6:08 pm
I have a tank mounted beside the sidecar, interesting that "Tour Tank" when googled takes you to the seller I got mine from:
http://www.coyote-gear.com they do very nice work, it takes a bit of work to mount it like I did but it's well worth it IMHO, if you need more info contact me off forum.
Posted : August 3, 2007 7:56 pm
(@SidehackRalf)
Hank, I don't know what kind of bike you have but I am very happy with the Samson tank I found on line. It fits on the passenger seat and is shaped so as to allow the rear trunk lid to open as usual on a 1500 Gold Wing. It is gravity fed to the top of the main tank which is under the seat and is easy to install. It has a back rest pad which is comfortable and quick disconnect couplings to remove it in a couple minutes. Give me a e-mail if you need more info.
Ralph
Posted : August 6, 2007 8:33 am
(@SideCar)
Tourtank mounted on the luggage rack allows me a gravity feed 2 gallons.
Posted : September 4, 2008 6:03 pm
(@hankhallmark)
thanks for all the input!
I'm sure I can figure out what to do with all the suggestions and information.
Thanks to you all/
Ride safe!
Hank
Posted : September 4, 2008 6:39 pm
I use a 3 gal. Tour Tank mounted in the trunk of my Yamaha Venture. I would not travel anywhere with out it. It gives me about an another 80 to 90 miles on my gas hog. I have a Champion Escort sidecar. I may have lost my trunk space on my full dress ride, but the trunk on the sidecar more than makes up for it.
Posted : February 7, 2009 5:53 pm
I use a 4 gallon Tour Tank mounted on a fender rack in place of the Pillion seat. It's plumbed into the fuel line with the valve just behind the seat by my left hand. With the 4 gallon auxiliary and the 4.5 gallon main I can get about 300 miles on the highways, slightly less in town.
The TT has internal baffles to prevent and control slosh and is easy to mount. It also comes in a variety of capacities from 1 to 6 gallons. Options are available make it easily detachable if so desired.
Posted : February 7, 2009 7:45 pm
(@hankhallmark)
Thank you for the continuing update.
"I use a 3 gal. Tour Tank mounted in the trunk of my Yamaha Venture. I would not travel anywhere with out it. It gives me about an another 80 to 90 miles on my gas hog. I have a Champion Escort sidecar. I may have lost my trunk space on my full dress ride, but the trunk on the sidecar more than makes up for it."
This style sounds interesting.
Is this tank mounted in the tour pak or the side bag?
Hank
Posted : February 7, 2009 7:53 pm
(@hankhallmark)
Originally written by Tomcat101147 on 2/8/2009 12:45 AM
This is an interesting approach but can it be custom-made to fit in a hard sidebag?
Who is the manufacturor?
Hank
Posted : February 7, 2009 8:00 pm
Originally written by hankhallmark on 2/8/2009 12:00 AM
Hank
Tour Tank is actually the maker. Their site is listed as Tour Tank. The tanks are all cylindrical to the best of my knowledge.
left profile
4 gallon tour tank
Posted : February 7, 2009 8:24 pm
My tank in mounted in the tour pax behind the passenger and is gravity fed to a split from my main tank. If I park on a up hill or down hill slope and the petcock on my main tank is in the on position, fule can drain from one tank to the other. On any long ride my Main tank is in the off position, I can travel between 80 to 90 miles before I switch to my main.
Posted : February 9, 2009 2:19 pm
