Hack tire...
(@big-tom)
I just picked up my Rig and find I need a tire for the Sidecar. Currently has a Bridgestone Potenza on it in 165/65/R13. I did a search on here and found nothing about a Sidecar tire. Plenty of Darkside info though..
What's a good replacement for this tire since it has been discontinued? I need to get one soon as it's at the wear bars.. Here's a pic of my Sweety trying the rig on for size..
Posted : July 3, 2016 9:23 am
(@sidewise)
http://www.carid.com/tires/165-65-r13/
Posted : July 3, 2016 12:13 pm
From the factory this sidecar more then likely had a 155 13 however a 165 will work. This is an automotive tire, any automotive tire store should have no problem helping you.
Posted : July 4, 2016 7:43 am
(@wingincamera)
Like Jay said, originally it was probably a 155/13 tire. I've never tried a 165.
I have used Firestone 745 F-560, size 145R13 24 psi and here is where I found them:
https://www.cokertire.com/145r13-firestone-f560.html $70.00
https://www.cokertire.com/145r13-vredestein-sprint.html $85.00
http://www.summitracing.com/search/part-type/tires/tire-size/145r13/tire-type/passenger-car/wheel-diameter/13-in
The sidecar tire I have on now is a Coker Verdestein Spint, 145R13, from Summit racing. $85.00 plus shipping, total $102.95 The Coker tire was a little more money but I wanted to see if it lasted a little longer. I average about 15,000 miles per tire. Since you indicate the Bridgestone Potenza 165/65/R13 will fit I might try the Bridgestone next time.
If your interested, on the rear of the bike I am running a 195/55R-16 Firestone Precision Touring at 28 psi
Posted : July 4, 2016 10:02 am
(@big-tom)
OK new question... I was going to take the Wheel off to shop around local tire shops. I have nothing that will fit on the lugs to get them off. Where do I get the lug wrench for the job?
Posted : July 4, 2016 10:20 am
Looks like you will need a thin walled socket for this one.
NWSC
Posted : July 5, 2016 8:58 am
(@big-tom)
Hack'n - 7/5/2016 10:58 AM
NWSC
I will also now need 4 new Lug Nuts....
Here is what happened to the thinnest wall socket I had. 12 Point so it didn't treat the lug nuts well.. Chalk line is where it had to be tapped in with a BFH..
Posted : July 6, 2016 6:39 am
(@RoanokeRider)
I have a similar wheel. No help getting the lug nuts now, but for future, mine came with much longer chrome lug nuts that stick out far enough to get a wrench on them. Likely can get them at any autoparts store.
Posted : July 6, 2016 6:43 am
(@big-tom)
RoanokeRider - 7/6/2016 8:43 AM
Thanks for the tip.. I will look for them after I find a tire..
Posted : July 6, 2016 7:17 am
(@big-tom)
Got those Chrome Lug Nuts today. Sure makes a difference..
Posted : July 6, 2016 11:51 am
Get the chrome acorn type lug nuts, thread is 1/2 inch 20 tpi.
Any tire store should have them.
Posted : July 6, 2016 12:33 pm
