Dark Side Front Tire
On my 2005 GW CSC rig when I got it was a Michelin Pilot Activ rear tire mounted on the front. Car tire on the rear.
It's now time for a replacement as the tire is cupping badly.
Why should I go Darkside again? I like the Bridgestone 709 I have on my 2006 Solo GW.
OK from looking at other sites it looks like a BT-46 is a good choice. Also since the tire has been upgraded it no longer needs to be mounted reversed.
BT, I mounted a BT-46 on the front on my Triumph rig after the BT-45 was discontinued. Was very happy with the BT-45 on a Goldwing rig several years back.
So far the 46 seems to be working out as expected. As for reverse mounting or not, there seems to be a lot of varying opinions on that, not sure it makes a huge difference in the end. Do what you are comfortable with.
Jan
OK, I found a BT-45 and it's on order.
- 2 Online
- 5,474 Members
