Tubless Tire
(@guitarzan)
Hi,
I have a Terraplane sidecar and I have a question. It has the original rim on it and a tire with a inner-tube. I want to go with a tubeless tire but I cant do that with the original rim, right? What would I have to do to be able to run with a tubeless tire?
Thank you
Frank
Posted : June 13, 2017 4:08 pm
(@oldschool_iscool)
Put a tube in the tubeless tire. Works a treat!
Posted : June 13, 2017 4:26 pm
(@85shadow)
You will need to change the rim to run tubeless, but keep in mind that most of the flat profile tires are tub-type.
Posted : June 13, 2017 4:29 pm
(@guitarzan)
I didn't know that most flat profile tires are tub-type. I was just thinking that it would be easier to repair a tubeless tire than one with a tube. I'll just run a tube tire.
Thank you
Frank
Posted : June 13, 2017 5:20 pm
(@beezageezer)
