Tri-Glide Triple Tr...
Tri-Glide Triple Trees
(@kghale)
Hi All
I have been reading the threads and thinking about installing these on my 2000 FLHT. Then I was thinking on a dresser they may not fit. The inner fairing and light bar attaches to the upper fork legs. The inner fairing on the Tri-Glide is set at a little bit of a different angle than the regular FLHT inner fairing. Any thoughts on this. I may be completely mixed up on this. Thanks for listening See Ya Ken
Posted : December 4, 2009 2:00 pm
It will bolt right on, all you need is the triple tree set, the metal "thingy" below the outer fairing and 1-3/4" longer fork tubes or use the tri-glide lower legs. Takes a weekend...
Posted : December 7, 2009 1:16 am
Say "Hi" to Gary Andress at the Harley dealer for me...
Posted : December 7, 2009 1:17 am
(@kghale)
Thanks for the reply, I'll have to add this to my Christmas list.
Thanks Ken
Posted : December 7, 2009 2:48 am
Jane1450 have you tried the TriGlide setup?
Posted : December 8, 2009 8:48 am
Yupp...Better then sliced bread n' bottled beer as my pappy used ta say...
Posted : December 8, 2009 9:41 am
Jane1450 Do you happen to have the part numbers ? Does this give you 3 or 5 degree rake ? Did you use the TriGlide sliders along with the triple trees ?
Posted : December 9, 2009 10:49 am
The sliders are the same.
The tubes are longer to accomodate the rake.
Spacers can do the same job.
Posted : December 9, 2009 6:32 pm
(@oldriders)
I would also be interested in the part numbers. I have a 2003 FLHTCI with a 1989 California sidecar. At 71 years and counting I need all the help I can get.
Posted : December 10, 2009 3:21 am
Here's the parts list...no, the sliders are not the same, they are taller. We went with longer tubes because we wished to re-use the custom legs on the bike.
H-D Part Numbers:
83374-09 Bracket Assembly, fork stem Approximately $200
83404-09 Bracket, upper fork stem $100
83453-09 Skirt, outer fairing $ 35
Optional longer forks:
83800-09 Fork Assembly, complete, Left $145
83801-09 Fork Assembly, complete, Right $145
Posted : December 10, 2009 5:47 am
(@timo482)
so 625 plus tax - complete all hd sidecar front end?
wow, thats a deal!
Posted : December 10, 2009 12:50 pm
(@bluehdmc)
Where did you get your parts. I checked an online HD dealer that states 20% off list and came up with a total of about $820, also left fork number showed up as NG. Still a better price than a Champion triple tree. The first poster mentioned the angle of the inner fairing, that could be due to the change in rake. I read on an HD forum that the wind seems to hit tri-glide riders with more buffeting that appears to be because of the rake change. Wasn't there also an issue with the fork stops?
Posted : December 14, 2009 2:11 am
My Husband does consulting work for H-D, maybe his price is better, what ever the case may be, ANY parts guy worth a damn should be able to get the correct #'s. If I had known about what a positive change raked trees would make I'd have done this years ago...my .02
Posted : December 14, 2009 7:10 am
I decided to go with Liberty Triple Trees and they are $815.00 shipped ,I should have them this week and will install while installing my TLE. The folks at Liberty are super nice regular price is $890.00 and they did 10% off. Check them out if you're undicided price was right for me and quality product and great customer service.
Posted : December 15, 2009 1:20 pm
I checked and the triglide lowers are longer to make up the difference
Posted : December 16, 2009 1:06 pm
