need sidecar for Ho...
need sidecar for Honda gl 1100
Hi all, back again, after a long hiatus. Still have the gl 1100 with velorex sidecar, that I found out here is a bad setup. I bought it as a combo, not knowing anything about sidecars, still don't know anything about sidecars 🙂
Well, I'm finally taking my rig to a local dealer/installer (he's listed on this site) to see what he recommends I do. I haven't used it much, but when I do it seems to slip/get out of adjustment somehow, left turns cause both bike & hack to lean in and stay there, still very spongy too.
I am still hoping to keep this combo, but was wondering if anyone could recommend hacks better suited for this bike (bigger/heavier). I'm sure the dealer/installer will say I need another one, but would like your ideas as to what will work, maybe I can make a trade with him for something that he has.
I am economically minded 🙂 It's my second ride, and will only be used occasionally, mainly to take my 5 year old granddaughter for rides around town, no long hauls. Thanks. Paul
Posted : March 12, 2004 1:21 pm
If you like the looks of the sidecar and want to keep it, upgrade the suspension with the heavy duty suspension option that uses a swing-arm with a 1" axle and a modular auto style wheel with a flat tread tire. That will make a nice tight setup with a tire that lasts a long time. I, (and others) make a conversion kit for this.
For the slipping frame mount, have the u-clamp spot welded on both ends. Right now you are probably clamped paint to paint surface and that isn't a good structural connection since paint compresses and wears off with friction. An extra lower rear strut can be added easily to make a 5 point connection, which is much solider. A lot of training rigs (which take a lot of abuse) use this mounting.
Posted : March 15, 2004 10:02 am
I am of the opinion that a Velorex even with a larger wheel and axle simply does not belong on this bike. I think you are on the right track looking for a stronger sidecar. Also I find that the "Universal" mounts that Velorex runs leave a lot to be desired.
The Velorex is a great little sidecar if mounted on the right bike, say around 400cc or so. I have found that I often times will hear people say that "you do not want a sidecar they handle poorly" when I get to talking about it to them more often then not the problem is that they had a Velorex installed (often by a profetional) onto a bike way to large for the sidecar. There are companies that advertize on this site that have real bolt on non univeral mounts for your bike.
Jay
Posted : March 15, 2004 11:06 am
Thanks for the replies. I'm not really thrilled with the Velorex, just kinda hate the idea of changing and all. I'm not even sure it is set up properly, due to the spongyness and slipping mounts, that's why I plan to take it to this installer, for some expert advice on my particular installation. I have thought of drilling a hole thru the slipping mount & putting a bolt thru it so it wouldn't slip, and adding an additional top mount to reduce spongyness (both top mounts now point in the same direction), but I'll wait and see what this guy has to say. Am taking it in Tuesday.
I agree it is too light for this bike (too many wheelies already) and the only reason I'd consider keeping it is because of the limited use it is going to get. Thanks again. Paul
Posted : March 15, 2004 12:16 pm
I have an 82 Goldwing Interstate with a California sidecar. It seems to be a good set up. You can jump up and down on the 1100's left foot peg and the car wont lift/budge at all. The car is solid and stable and has a flip up front end that makes getting in and out easy. It looks great with the Goldwing and its smooth as silk on the highway........There is alittle bit of wobble at low speeds, but with both hands on the bars its not even noticable. California Sidecars has mounts/brackets specifically for that application. You can usually pick up a used car on Ebay at a reasonable price
NoBrakes
Posted : March 16, 2004 12:34 am
Another opinion.
I feel Jay is being a bit restrictive in his assessment of the Velorex sidecars. There are probably more Velorexes mounted on Japanese, British and Italian cruisers than any other brand. The 562s are ranging in serial numbers well over 301,000 as I write. However, not everyone is a Velorex dealer and would perhaps like to promote their own products. That's the American way. No sidecar is ideal for all motorcycles or all uses. We have installed Velorex 562s on bikes as an economical entry level sidecar, then remounted a larger and more expensive car later as the clients proficiency increased. By the same token, we have installed large, expensive sidecars and had the customer trade them back in for a Velorex because they were too cumbersome and were too hard to handle without spending a lot more money. We never recommend a light sidecar for touring or high speed use on a heavy bike. Many folks need a third wheel for balance and are not interested in speed or "flying the chair" as it were. Some just want to putt around the neighborhood or go to the store. Some just want one for temporary use and don't want to spend a lot of money for a hack that they will just have to sell later or use for a planter.
Like Smith and Wesson products, Velorex products are well made, but perhaps not always used properly.
There's no need for an answer to this post, it's only my opinion.
Posted : March 16, 2004 7:59 am
I can see where Hack'n is coming from, but I think you must also look at the idea of resale. Just because you may not go over 30mph doesn't mean the next owner won't and then come back on you if he has problems. I still feel that the Velorex, Spirit, Cozy, HitchHiker, and similar sidecars are much better bets on smaller bikes. I had a HitchHiker on a GL1200 and could lift it off the ground simply changing lanes on the highway. When I contacted the company, thinking that I had made a mistake in setting it up, they suggested that it was designed for much smaller bikes than mine and that I should trade it in on their double wide model or mount it on something much smaller. Like everyone else though, this is only my opinion and others will disagree. Being the webmaster only means that I know something about computers. It doesn't necessarily mean that I know much about sidecars. 🙂
Posted : March 16, 2004 9:48 am
For what it's worth Mike I agree on your views that the sidecar is really too light.
I also agree that you know your computers and I am sure glad...keep up the good work!
Posted : March 16, 2004 4:39 pm
