Motorvation Formula...
Motorvation Formula II open access
(@RNMedic)
jaydmc - 1/26/2017 10:22 AM We find more often then not a tilt nose sidecar is not the best answer. A sidecar with a cut down side or a door in it with a step is often much easier to live with as usually these type of sidecars have a higher seating position and as such your feet are more under you then laid out forward.
we actually looked at the Urals first and the door/step may be a option. this one was just too good of a deal to pass up.
Posted : January 27, 2017 4:30 am
I don't think the door idea will work with our cars, the windshield placement would be an issue more than anything. but I suppose you could have that redesigned to work
I am curious to hear what the body shop has to say
Posted : January 27, 2017 4:59 am
(@RNMedic)
after looking at the car I agree and may have to go with a purchase in the future, I'll keep you updated.
Posted : January 27, 2017 6:03 am
(@RNMedic)
after much research and some images of the hinge system on the motorvation and the expense at a body shop we will ride as is and look for a easy access when the budget allows.
Posted : April 24, 2017 7:08 am
the good news is that now that your rig is set up you can look into just replacing the car body.
Posted : April 24, 2017 9:20 am
