Leading link instal...
Leading link install questions, and other info.
43 Reactions
Quick_Cal
(@calvin-watson)
Calvin, two points here...WHY is the rear axle bolt hitting the right side muffler, when 99.999314159 percent of the other Goldwing 1500's  don't have this problem ?
Secondly, rather than cut off the threaded end of the bolt...why not space the bolt out to the left, by placing one or two thick washers under the head of the bolt, on the left side of the bike, before sliding the bolt through the rear differential ???
Oh ya. I think I'll ask the Goldwing guys (or anyone here with a 1500) to air up their rear shock and see if the bolt hit's the muffler?
Posted : May 13, 2024 5:54 pm
I feel  SO bad for  Wilton, thee Dog.  friday
Calvin,  I  previously owned a  1994, and  a 2000 Goldwing  1500, and on both of them I removed the  original  rear shocks, and  installed  Progressive  Suspension  coil springs shocks,  and neither of those  bikes ever  had the  rear axle bolt  hit a muffler,  on either side.  Both bikes were ridden  HARD.
And I  just polled all previous  owners of Goldwing  1500's, and  they  all agree....everyone  of them....we all feel SO bad for  Wilton thee Dog.
Excitement
In reality,  I  would  bet that  at least  75% of all Goldwing  1500's  had the rear suspension  replaced,  because  that was the  biggest  flaw on those bikes.  There was an air shock on one side, and a coil spring shock on the  other side,  so  in high speed sweepers the bike  would wallow.
Posted : May 13, 2024 8:40 pm
sheath reacted
(@varn-cummings)
Wow. I forgot about that. I had a 1988 & a 1997 1500 and had forgotten about that 1side had the adjustable air & the other coil over.
Posted : May 13, 2024 9:52 pm
Quick_Cal
(@calvin-watson)
Hmmmm. I just watched a bunch of Goldwing videos trying to get a look at that bolt. They all look like it's up there where mine is,,, from what I could tell.
One video in particular showed  a guy installed these same 412 shocks. He set them on max load. He said it raised his bike about 1.5''.  He made no mention of the bolt hitting.
So I don't know what the heck I've got going on. It didn't hit before I swapped final drives. The one I installed is supposed to be out of a 93. I don't seem to be having any other issues.
Posted : May 14, 2024 7:39 am
Calvin, Caretaker of Wilton thee Dog, aka...Sidecar Willie, before you installed this used Rear Diff, did you make certain that it was the exact same outside casing as you old one?  Placed them side by side, and carefully compared them,,,every nook and cranny ?
I would love to see a picture, or two, of the LEFT side of this replacement rear diff, with the axle bolt installed.
Posted : May 14, 2024 8:17 am
Sounds like there is something causing offset.  Not being a GW veteran, I can't offer anything specific, but there has to be something causing it to be shifted to one side.
Posted : May 14, 2024 9:07 am
I know I'm not there to see it, but, the mufflers can pivot inward and outward where they meet the collector box, if I'm remembering this right why not just bend the tab on the muffler where it mounts to the saddlebag bracket a little and twist it out a little to clear the bolt all together
Posted : May 14, 2024 9:27 am
Quick_Cal
(@calvin-watson)
I compared both final drives before I installed. They looked the same. I just looked at them again, all though I can only see the right side. They look the same. I compared all the parts using partzilla. They all interchange from 93-96.
There's no moving the swing arm over. So that's where it has to go. The new final drive bolted up just fine.
Sure seems like if I had a major problem I would be able to tell with the 300 miles I put on it?
Let's see if I can get these in the right order. This is the space between the washer and frame with REPLACEMENT FINAL DRIVE.
IMG 1200
Here is the ORIGINAL FINAL DRIVE spacing before removal.
IMG 1017
IMG 1011
Posted : May 14, 2024 6:28 pm
