Harley Rig Bike Lea...
Harley Rig Bike Lean Adjustment
If I move only the bar that slides under the car that attaches to the bike near the steering head,will this change bike lean and not change toe?
Posted : July 26, 2007 6:22 am
It will change the toe-in.
Posted : July 26, 2007 6:56 am
 PUZ
(@PUZ)
You sure about that, Lonnie?? If you don't adjust either of the lower mounts, toe-in movement is almost nil. The S-shaped tube that slides in mounts under the sidecar chassis and mounts just below the steering neck on the bike sets the lean-out. At least, that's how it looks on my ElectraGlide/TLE setup.
Don
Posted : July 26, 2007 1:36 pm
Any change in the attitude of bike/hack combo will cause some change in the alignment of the car. Maybe minor, maybe not.
It's always wise to check the toe-in after any adjustments of the mountings are made to insure proper alignment and minimal tire wear.
Posted : July 27, 2007 8:50 am
(@gnm109)
I check my toe-in on my HD rig with two 10' pieces of 1-14" square tubing set up with feet so they contact the tires at about 4" about the floor. Changing lean a degree or two results in negligible toe-in change. That is because the toe-in is very tightly controlled by the two lower mounts.
I can imagine that an extreme change in lean might affect the toe-in but I see no need to make such a change.
Posted : July 29, 2007 7:39 am
if your front and rear lower mounts are exactly the same height off the floor, the toe in wont change when adjusting the lean in/out.
Posted : July 29, 2007 7:52 am
(@gnm109)
Originally written by Bob in Wis on 7/29/2007 9:52 AM
Good point. That explains it. The ones on the Harleys are almost at the exact same level.
Posted : July 29, 2007 8:24 am
Originally written by gnm109 on 7/29/2007 1:24 PM
Distance of them from the centerline of the bike makes a difference also.
Posted : July 29, 2007 11:45 pm
