Half round aluminiu...
Half round aluminium beading
(@Sidcar)
Any sidecar restorers/coach builders out there? I'm in the process of fitting half round aluminium beading round the edges of a sidecar I'm rebuilding. Progress is slow as I'm offering the beading up, then bending it a bit, then try it for size, then repeat the process. Also on the bit I've done I have a gap between bead and bodywork the thickness of the pane edge I'm covering up. I intend to fill this with black sealer unless someone knows better.
See pictures (with luck)
Sid
Posted : July 29, 2018 5:37 am
(@rudyr)
Have you tried raping one of ratchet straps around the trim and the box tithing it up to hold your trim in place. I think it would take about 3. One closet to the bend, then take rubber mallet to bend the trim. Just a plane.Rudyr
Posted : July 30, 2018 3:57 pm
(@Sidcar)
I got in bent round eventually. I bent it a bit, then annealed it, then bent a bit, then annealed it and so on. Any twisting I got rid of with subtle use a vice fitted with plastic jaws. Now to do the other side.
Posted : July 31, 2018 8:15 am
