Clutch Lever hard t...
Clutch Lever hard to pull.
9 Users
50 Reactions
(@jim)
Jim Floyd....google Barnett Clutches. You want a lockup clutch. It cuts the clutch pull in half. It uses coil springs instead of a diaphragm spring and you can change clutch pressure by changing the springs. Just put one in my 06 Ultra that's tied to a Texas Ranger sidecar. No problems with it...
Posted : July 4, 2024 11:12 am
(@green-sidecar)
Thanks for the continued suggestions. I am in the process of extending the clutch lever and handlebar on the left side. If that doesn't work I'll try some suggestions. Thanks to all for the support!
Posted : July 6, 2024 11:37 am
(@metalcarver)
Adaptive Technologies.  Here's the fried cat's pajamas.  The clutch lever is converted to a position idicator and the muscle is provided by a linear actuator. $$$
Posted : July 7, 2024 3:05 pm
(@metalcarver)
Actually I think that you could use that device to transfer clutch control to a knee or thumb lever.  Chin?  Elbow?
Posted : July 7, 2024 3:10 pm
