Champion escort 10 pin connector
Anyone have a number or manufacturer of the dual gender 10 pin wiring connector on the Champion Escort sidecar? also, what is the pictured black connector for?
Try calling here on Monday. Good luck.
EMAIL
BILLS@CHAMPIONSIDECARS.COM
OFFICE
11841 MONARCH ST
GARDEN GROVE, CA 92841
714-847-0949
800-875-0949
Two connectors in your photo. The metal one is for your brake quick disconnect. The other is for a radio antenna.
We normally cut the Champion plug off as their harness is far to long. This allows us to clean up the wiring.
You did not ask but I thought the pin out for the plug might be use full to you.
1 clock, green 22 gauge
2 accessory Red 18 gauge
3 Ground Black 18 gauge
4 Brake light Red 22 gauge
5 Running light White 22 gauge
6 Right Turn signal Yellow 22 gauge
7 back up Blue 22 gauge
8 Canopy switch on bike Orange 22 gauge
9 Tilt Yellow 14 gauge
10 Tilt Pink 14 gauge
Thanks as always Jay. I had downloaded the Champion manual so had the pin out info, but that antenna connector was a mystery. I was looking for the plug model so could make my own harness to the bike.
Champion only sells a harness and I really only need the connector. Anyone have info before I cut it off and replace with another type. Wire size up to 14 gauge if anyone recommends a particular replacement.
Okay, in the unlikely event anyone else needs the info, the manufacturer is Sure Seal. Model pictured is their 120-1870-000. I ordered its matching part 120-1869-000
- 93.3 K Posts
- 5,436 Members
