ABS Brakes
Connecting a 2005 TLE with disc brakes to a 2012 Ultra with ABS. Anyone know how or where to make the connection of the sidecar brake? i read somewhere to do it before the ABS unit but where should it be done? Thanks for the input
I have a 16 ultra hooked to a 07 tle side car. Harley says you cant do it. But it works great. I have put 9000 miles on it so far. I will have to look where the connection was made.
That's great. I was also told that 2013 was the last year you can install a factory made sidecar because of frame changes and that there is no place to bolt the rear mount. Any picture of the mounts and brake connection that you can post would be great. Thanks again.
the frame changed i believe in 09 you would need the new mounts. the bolt holes are still there on the 14 but need to be tapped. Txt me at 618-806-5505 and i can take photos and send them to you.
- 5,471 Members
