80's velorex 562 sh...
80's velorex 562 shock question (update)
(@saophoto)
Hi folks!
I believe my 562 is an 84 model and I am looking to replace the shock (it looks like it might be the original). I just replaced the rear shocks on my bike and know the velorex is way too bouncy...
I did search the forum and the posts that I found were really old.
Does anyone know of a direct replacement for the shock other than velorex, or one that will need minimal modification?
I have heard that some of the 11.5 sportster shocks will fit by grinding the eyes.
Any thoughts, harassment, or wisdom appreciated!
Posted : August 1, 2019 7:10 am
(@85shadow)
(@saophoto)
Thanks for the link 85!
were any modifications needed to make it fit?
my current shock is quite bouncy and I am sure since it is the original, or appears to be, it is due for a change....
Posted : August 20, 2019 12:13 pm
(@85shadow)
It comes with 10 MM ends so you have to change to the 12mm ones from your old shock. but other than that fits great.
Mine was shot :
Posted : August 20, 2019 2:26 pm
(@saophoto)
wow! that does look pretty far gone!
do you mean switching out the grommets in the eyes?
pardon my ignorance, not sure what you mean by the ends.....
I am hoping to be fully prepared before I start disassembling....
Thanks again!!!!
Posted : August 20, 2019 3:08 pm
(@85shadow)
Yes, they come setup for 10mm bolts, the OEM ones use 12mm bolts.
Posted : August 20, 2019 3:13 pm
(@saophoto)
Super fantastic!!! thanks for the info 85!!!!!
Super excited to have this info and will be ordering a shock now!
Posted : August 20, 2019 3:16 pm
(@saophoto)
Hey, 85Shadow, quick question..... is it hard to push out and replace the grommets in the eyes? Can it be done with basic tools?
Thanks again!
Steve
Posted : August 22, 2019 6:21 am
(@85shadow)
It's not hard to remove bushings but putting the Velorex in to the new shock will be easier if you file the center of the eye out some.
They taper down in the middle and that makes for a very tight fit. A vice or C-clamp will make things easier.
Posted : August 22, 2019 3:19 pm
(@saophoto)
Got it! Thanks!!! Shock should be arriving today!!
Posted : August 23, 2019 2:25 am
(@85shadow)
Update?  How did the install go? What are your impressions?
Posted : August 27, 2019 11:08 am
(@saophoto)
Hi Shadow! Thanks for checking in, the shock arrived but haven't had time to install it yet.
I will keep you and the forum posted.
How are you liking yours?
Posted : August 27, 2019 11:12 am
(@saophoto)
Hi 85 Shadow!
Install complete! Hardest part was getting the old shock out and mine came out in pieces too!
I notice the ride is much firmer and although nothing shifter, now seem to have, not really wobble, more of a bounce.
I left the adjuster in the same spot where it was when I got it, did you have to change the settings on yours?
What will adjusting the shock due?
pardon my stupidity, I have just never had cause to adjust one....
It seems to make sense that a stiffer shock would give a stiffer ride and not much play to compensate. I wonder if more weight in the car would make a difference....
Now when I stand on the floorboard, the car no longer sinks two inches or more.... hardly moves!
Here are some shots of the adventure....
Posted : August 29, 2019 5:57 am
(@85shadow)
Glad it went in OK, I left mine where it was also. That adjustment changes the preload on the spring so it will carry more weight! Don't need that, if you don't have ballast in your car I would  recommend adding some.
Posted : August 29, 2019 7:37 am
(@saophoto)
thanks for getting back to me! yes I was thinking it needed more weight now that it has actual suspension! Not much ballast in car other than toolbox and two 10x10 cement squares, i was thinking of throwing in a bag of cement and seeing how it does.
right now in southwest fl it is just too hot to mess around with it until the sun goes away.
Do you keep a lot of weight in yours?
Posted : August 29, 2019 7:43 am
