2007 Harley Ultra S...
2007 Harley Ultra Sidecar
I don't know where the speedo is driven from on my 07 Fatboy. I guess off the front sprocket like some other bikes. Changing the rear sprocket should't effect the speedo.
Posted : June 27, 2007 1:07 pm
(@gnm109)
Originally written by quack947 on 6/27/2007 3:07 PM
The speedometer is driven by the speed sensor which is in the right rear top of the tansmission. It reads pulses from a magnet inside the transmisison. Therefore, changing the rear belt ratio will change the speedometer reading. This is bad Ju Ju.
http://www.randomhouse.com/wotd/index.pperl?date=20010510
Posted : June 27, 2007 1:42 pm
You can take it in and have the HD tech recalibrate the speedo, so they say, I have never done this.
KC
Posted : June 28, 2007 1:45 pm
(@gnm109)
Originally written by Bluecedar on 6/28/2007 3:45 PM
KC
Good luck on getting that one right. Sounds terribly expensive at $90 per hour.
Posted : June 28, 2007 2:06 pm
You can also use a GPS unit for the speedo. I have a BMWLT that the speedo is 10 miles slow at 70, I use the gps for a more accurate reading. Also BMW says this is for our own proctection. It looks like your going faster so you want get a ticket. Also this is within their specs. since they want fix it under warranty.
Posted : June 29, 2007 6:38 am
I notice in the parts catalogue that up to the '03 models you could get a high load drive belt Part No. 40130-03- which would seem sensible as you are putting more strain on that part ( and other parts as well)
Was it ever fitted as standard? You would think it would have been.
The standard belt on the '07 models looks so small- no High load belt is listed for these and there is more power on hand.
Paul
Posted : July 30, 2007 11:16 am
(@gnm109)
Originally written by sidecarbrit on 7/30/2007 1:16 PM
Paul
In 2004 HDMOCO changed the rear swing arm and pulley width to accomodate the larger 150mm rear tire. At that time, they started using a narrower belt that, I am informed, is stronger than the previous larger pre-2004 belt. It is P/N 40024-04 with 139 teeth.
The 40130-03 "High Duty" belt wasn't a great seller at $239.00 plus 6-8 hours labor for a changeout. AFAIK, it was never fitted as standard but is still advvertised for 1997-2003 FL's as an accessory for sidecar use.
With proper care, I realy doubt that you will have any trouble with your rear belt. It's best to stay away from gravel and dirt roads however, since a stone can damage the belt severely.
Oh, yeah, don't do any burnouts, either. Ha.
Posted : July 30, 2007 2:17 pm
(@timo482)
actually the ultras, classics, and kings come with the high load
only the road glides did not
who knows why
later
Posted : August 2, 2007 12:01 pm
(@timo482)
High Load Drive Belt
This high strength belt is manufactured to improve belt life due to the heavy duty loads required by the addition of a sidecar to the motorcycle.
40130-03
Fits all '97-'03 FLT models
Posted : August 3, 2007 5:38 pm
Well as I said before the Belt looks very much on the Light weight side considering it was bought from HD as a complete Rig- and the bike is an Ultra Classic.
So How did I get the rig - 6ft 4ins into a 6ft garage door - easy - Picture enclosed!
Paul
Posted : August 18, 2007 10:46 am
(@gnm109)
Originally written by sidecarbrit on 8/18/2007 12:46 PM
Paul
Although the 2003 and later belt is somewhat narrower than prior belts, it is made from stronger stuff. They seldom fail in actual use and, if you have a steady hand on the throttle, you won't put any more strain on it than a solo bike.
I'm not really concerned about mine. Kits are available in the aftermarket to convert a belt drive HD to chain drive. The down side is that chains are a bit on the messy side snd a little noiser than a belt. That could put your mind at ease, I guess. If you were to change to chain drive, you could easily gear the machine any way you want without modifying the primary ratios. I estimate about $350 for parts with two sprockets and a #530 O-ring chain if you do your own work. (I do)
BTW, don't you mean a six-foot wide biue and a six-foot four garage door?
Looks good.
Posted : August 18, 2007 12:39 pm
No the Garage door opening is 6ft and the Rig is 6ft 4ins- just needs a bit of manouvering!
Does anyone else get an engine surge when you are decelerating- you are using engine braking to slow down and as the engine revs get less- suddenly it speeds up and then slows up again- a bit unsettling.
Posted : September 19, 2007 6:55 pm
(@timo482)
id consider going to chain drive [the new chains last way way longer than chains in the 70's did] if it would allow me to get a 180 tire in there - im running a 15" car tire & it works great but id much rather run radial motorcycle tires - 130/r18 front and 170/r17 rear now that touring radial motorcycle tires are availible.
Posted : September 20, 2007 4:42 am
(@gnm109)
Originally written by timo482 on 9/20/2007 6:42 AM
A chain drive would be a good change for a sidecar. A nice #530 O-ring chain would do nicely. The aftermarket suppliers have kits for the Electra-Glides. It's a lot of work, however, although you would get some piece of mind and it would be fun to ride on gravel roads again. I stay off of gravel with a belt drive. I've seen what happens to a belt when it gets a piece of gravel or rock in the path of the belt.
A chain drive would likely permit a larger tire. My 2004 has a 150 tire and I doubt I could squeeze much more in. The A/M suppliers also have kits for wider tires using belts but it takes a major re-work.
Posted : September 20, 2007 6:39 am
(@timo482)
when the current tire wears out im going to look into either a chain drive kit or a wide tire kit. the biggest problem with the 15" wheel is the brake caliper - its a act of congress to get the wheel in or out. i have to first remove the pads, put the bolts back in and then work it out and its a hard fit then. just sucks. and to make it worse i have a parking brake as well - two calipers to work off the rotor with nearly no clearance.
the tire and wheel work really well however. handling is wonderfull.
still a larger tire 16" or 17" dia, radial, touring motorcycle tire,
of course with the new se roadkings runing radial tires.... eventually i think we will see ultras with radials.
Posted : September 21, 2007 7:19 am
Page 4 / 12
