Trailer for a sidec...
Trailer for a sidecar rig
9 Reactions
(@big-tom)
Does anyone haul a sidecar rig on a two bike fold up Kendon trailer?
Posted : June 6, 2023 11:41 am
CCjon
(@jan-2)
Had one of those trailer when I had a Ural. Fit perfect. Since then, the next rigs were too wide, so sold the trailer.
Measure your rig and the trailer carefully before buying. Other than that, they are well-built trailers, should last a long time.
Posted : June 6, 2023 11:59 am
(@smitty901)
 Small rigs may fit larger ones will not.
Show us what you are trying to haul.
Posted : June 6, 2023 1:16 pm
(@big-tom)
Yamaha Venture with a Hannigan
Posted : June 6, 2023 1:54 pm
MJ reacted
(@smitty901)
Will not fit. on the one you posted.
Should fit but even then need measurements.  Also trailer only weight 450 lbs.
Posted : June 6, 2023 4:20 pm
@Big Tom, I just recently ordered a new trailer, because my new sidecar rig is W I D E.
When I grow up, I want to be just like @CCJon, Jan Daub, our El Presidente', so I ordered the exact same trailer he has, a Bear Track BTU82120s.
https://beartracktrailers.com/product/82-wide-utility-trailer/
My all-in cost for this trailer, including an extra spare tire & wheel (not the mount...just the spare tire & wheel), was $ 3,800.00
These are surprisingly lower priced than any other ALL ALUMINUM trailers I have searched.
Search the Bear Track website for a dealer close to you......most likely you will have to order this particular one, as most dealers don't stock one, but there are a few around the country, so you might get lucky.
Posted : June 6, 2023 6:30 pm
Thane Lewis reacted
(@big-tom)
That Bear Track looks like it would fill the bill. Closest dealer is in OK City. I've been looking around Phoenix for an aluminum trailer and no joy so far. I expected to pay around $4K so that trailer is in my ball park. I'll be making some calls.
Thanks for the info.
Posted : June 7, 2023 3:02 am
@Big Tom, just to give you a tad bit more info, those two aluminum fenders are easily removable....just 4 bolts on each fender, so if it is going to be a tight fit (like my rig will be), then just zip off those fenders quickly, run the sidecar rig up onto the trailer deck, once it is secured in place, then reinstall those two fenders.
I have checked these out in person at the dealer I ordered mine from (In Oregon, despite me living in Washington), and was pleased with the quality.
That rear ramp is a bi-fold. You can order it with a non-folding ramp, but WHY ?
Posted : June 7, 2023 3:32 am
(@smitty901)
My bear tracker
12 feet long inside
82 inches wide
Fender to fender inside 84 inches. I did move one out 3/4 of an inch easy task.
 I really like the light weight 450 lbs and the curved ramp . It makes loading any bike or rig easy.
Had it awhile paid in range of just over $3,000 if I remember right. It gets a lot of around the farm and house use also.
Posted : June 7, 2023 6:07 am
Since some discussion arose elsewhere, possibly about trailers, I offer my solution.  The link goes to the ADV Rider site but I will post a few pics for good measure here.  https://www.advrider.com/f/threads/sidecar-trailer.1524267/
rig on trailer front
rig on trailer
underside anchor
wheel chock
ratchet strap
The winch cable is attached with a shackle to the lower front mount bar between car and tug.  I snug it up as a primary anchor.  Between that and the wheel chock, there is very little movement and the ratchet straps allow for very quick attachment and release.
While the trailer does tilt, there is no way to get the rig onto the deck while tilted.  So I bought steel ramps rated at 750 lbs each.  Given the weight of the tug and car, adding me to the mix would overload the tug side ramp so I use the winch to drag the rig onto the trailer.  I had my vehicle wired with electrical quick connects directly to the battery.  Once lined up, it's about 45 seconds of winching to get the front wheel into the chock cradle.  Same story to get it unloaded.  I can't quite do the whole thing solo because it needs to be guided into the chock but it's something Karen can do to help by making the electrical connections.
Posted : May 26, 2024 11:09 pm
There are at least  3 of us here.....Jan Daub, @smitty901,  and  myself  that  have  the Bear Track all aluminum  trailers, and we love them.
Check out the  Bear Track  BTU82120S, or the  BTU82144S.
Posted : May 27, 2024 6:59 am
