Sidecar installer i...
Sidecar installer in Arizona ?
(@big-tom)
I would like to remove it from my Yamaha and install it on my Goldwing.
I would take it back to Hannigan but 1603 Miles intervene.
Posted : May 14, 2023 4:25 am
(@webmaster)
Honorable Member Admin
Tom,
Look on the main menu of the sidecar.com website, under "Sidecar Library" you will see the top menu item "Map of Sidecar Manufacturers, Dealer, and Installers". If you click on that you will see a Google Map, but that is a static image. If you click on it, it will open in a new tab to a Google Map of all places. From there you can zoom in on Arizona and you will see 3 places listed. Research those to see if they will fit your needs.
Jerry
Webmaster
Jerry
Posted : May 14, 2023 4:43 am
(@big-tom)
Thank you. I see three. I'll make some calls this week...
Posted : May 14, 2023 5:39 am
Also, Tom, if you call Hannigan, and talk to either Stephanie, or Dave, or Corey, they can tell you the name of the shop in AZ that does installations of their Hannigan sidecars...for them. Might be a good source to use the same shop that Hannigan uses for installations in AZ.
Posted : May 14, 2023 6:18 pm
(@big-tom)
I spoke to Hannigan today and they have no installer in Arizona.
Posted : May 16, 2023 10:24 am
(@michael-hawkins)
There is a shop in Prescott, AZ. called Dying to Ride. I just learned of it while on a ride through Arizona a couple weeks ago.
Posted : May 25, 2023 11:03 am
(@big-tom)
I spoke to this fella on Friday and he is definitely a shop that installs Hacks.
https://dyingtoride.com/
Posted : June 11, 2023 4:39 am
