will trya gain- New...
will trya gain- New to sidecar
I will see if this works this time, fat fingers
I have read a lot of the info posted here. Thank You ALL. and will still need help. I just made a deal to get a Motorvation Formula II. the car 1980 some thing? It was on a old wing and I will be putting it on a 1980 XS1100. When I get it i will see what type of mounts it has then I should able to ask for more help I have never had a car on a bike and have read that I will need to practices a lot in a parking lot. I have been riding a long time started when I was 15 and I am now just about 60 wife needs more than two wheels now so any help I can get will be grate
Thanks cpcarroll
Posted : October 17, 2007 3:27 am
make sure you get a flip nose FII; it is a lot easier for your wife to get in and out. the solid body one is hard to get up and over the wide fender, onto the seat, then crawl in and sit down. harder getting out!
lot easier packing it also. for camping, and daily trips.
Unless your wife is very tall and has strong arms.
We have a flip nose and love it!!
Posted : October 17, 2007 7:43 am
Welcome to the madness Chuck!
The XS110 will make a strong tug for your Formula II.
You will need decent rear shocks for it as the Yamaha rear shocks were pretty flimsy when new.
I have used Harley Sportster shocks with the Yamaha bushings (metric) inserted in the past for an inexpensive changeover. Picked up the shocks for $20. from a cycle salvage yard. New Progressive shocks would be nicer but it will depend on your sidecar budget.
You will probably need a steering damper with the XS due to excessive trail to keep it from wiggling it's nose at low speed but that is something you will have to deal with later. Some are easily controllable without one while others are not.
If your's is a higher mileage XS I would also change out the steering head ball bearings and install new clutch plates for insurance.
nwsidecars@aol.com
Boise, ID
Posted : October 17, 2007 8:04 am
Wellcome. Our backgrounds are similar, I started riding when I was 14 (Arizona) and will turn 60 next summer. Got into sidecars a couple years ago due to medical issues with Connie. We both love it, best theng we could have done. Went to Alaska this summer on the hack.Sidecaring is quite a bit different, but you should take to easily. There were no sidecar classes in SoCal, but if there had been one I would have taken one. I think there are many in your area (?). good luck! greg
Posted : October 17, 2007 8:35 am
(@xs1100sgman)
Hi and welcome to the sidecar world. My first rig was an XS1100 Special and the Auburn Gemini 2 seater (There's pics in the albums section). This should be similar to what you are setting up. Hack'n is right, there was a low speed wobble. I gripped the handlebars tight at start and after 25 or 30 mph all was okay. The steering was a little hard but not too bad unless you plan to do more than a 100 mile trip. Maybe you should consider raked trees or leading link forks. Good luck and take it easy until you learn the ropes.
Regards, Les
Posted : October 17, 2007 1:51 pm
I have had two rig sbased on an XS1100 and we enjoyed both of them. One was a Motorvation Formula II (non flip nose).
The wobble is nothing to worry about once you get used to it. It may copme at a given slower speed and soon you can learn to accerate through it while keeping your hands on th ebars and after a while it will not even be noticed.
Rear stock shocks are pretty soft as Lonnie mentioned so expect to beef up the rear somehow and you will be happier.
We Utilized wider motocross bars and steering was okay.Note that if you have a standard XS1100 and can swap out the forks for some off of the 'Special' and you will get a reduction of trail and easier steering using all stock parts.
Main troubles we have had with the older yamahas were that th emaster cylinders seems to go bad in time. They woudlk not allow th efront calipers to relaese properly. Had this happen on both XS11s and our XS650.
We ran a avon triple duty sidecar tire on the front most of the time and a dunlop 491 on the rear. No fork brace was run.
We did not run a subframe on these bikes but really should have.
Excellent tug. Had done a 750 mile day on it and a lot of 500 or so milers.
One bad thing is that fuel milage REALLY goes down as speed goes up. Dunno if all of them are as bad as ours were though.
Posted : October 17, 2007 2:28 pm
I just put a Motorvation Roadster Royal on my Suzuki 1500 Intruder...Gary at Motorvation was very helpful with mounting and parts needed to make it work on my Zuki as it is my first car also...I have a few spare parts for mounting onto a bike if your missinf any I assume they will be very simular for your car too....new arms/parts are very $$$ from Motorvation....Steve
Posted : October 18, 2007 3:55 pm
