what settings for a...
what settings for adjusting progressive shock
zrx 1200 - 540lbs wet . no probs with pulling.. 70mph all day. i have the the updated shock / axle from dauntless and wondering what shock setting are most of the hackers using. would it be advantagous to set it to the most firm for handling? i mostly ride with 100lbs. ballast and if i have passengers i take out..i tried soft setting but noticed alittle bouncing on freeway dips or should i go max firm and see what happens albiet banging around like a rollercoaster ride.... wheeeeeeeee!
Posted : August 16, 2007 7:40 pm
At the risk of sounding like a SA I say play with it, go to soft and work your way up, be sure to do some heavy left turns to see if the rig drops too much, try to use the same stretch of road so you can compare each setting.
Posted : August 22, 2007 9:30 pm
(@peasandcorn)
I run mine as stiff as i can get it.....
no squishy right handers.
Posted : August 26, 2007 1:11 pm
