Velorex 562 Brake
hello,
How do I go about hooking up the hack brake? Does someone make a foot brake lever that you attach to the hack frame and can be used in conjunction with the bikes rear brake? Any ideas? Thanks again, Ryan
On bikes with drum brakes on the back you can put a clamp on the rod that pulls on the bikes rear brake that will also pull on the sidecars brake cable. You then have to anchor the sidecars brake cable housing.
Jay Giese
Dauntless Motors Corporation
On bikes with rear disc brakes most times the cable can be rigged up to hook onto the brake pedal itself so when the pedal is pushed down the cable is pulled. The cable sheathing must be secured as close as pratical to the hookup. After you get the Velorex brake hooked up please let us knwo how you like it.
Ok thanks guys. As soon as I get the rig back together (painting it) I will let you know how the brake turns out. Thanks again.
- 8 Online
- 5,474 Members
