sidecar brakes
Ever think of useing an auto dual system master cylinder when hooking up disimilar brakes? When building street rods the GENERAL rule of thumb is 7 to 1 for the pedal leverage. Cylinder size is alot more complicated. The smaller the master the more pressure you will have but at a loss of volume. I learned the hard way that if you mount a master cylinder so that it will be lower at anytime than the slave it needs a check valve in the line. This applys to disc as well as drum brakes. Speedway Motors in Lincoln Ne used sell an adjustable proportioning valve for about $50. That was a few years ago so the price is probibly way off. Hope some of this helps.
David
Posted : January 2, 2005 5:04 pm
David,
You mentioned Speedway Motors...Excellent source for parts adaptable to sidecars. They also offer free catalogs .
Another place woth looking at is StockCarProducts.com. who also offer a free catalog.
Posted : January 3, 2005 1:54 am
Summit Racing has quick adjustable lever style proportioning valves for $75.95. Part # WIL-260-8420
1-800-230-3030
Posted : January 3, 2005 8:27 am
