Shock For Spyder
I finaly found a shock for my Motorvation Spyder, not an air shock but I think better than the stock one, It's a "Showa" MCH-003, 12 1/2" between mounting holes which might be a little shorter than stock, the rear edge of the fender is a little higher off the ground now, was told it was on a VTX 1800, I think the rear fender sits the way it should, I always thought it sat a little low in the rear, got it from a place that puts alot of trikes together,good deal, $25.00, now I may have to adjust the lean, will see, later, Doc.
Posted : June 14, 2007 10:05 am
Sounds like you got a deal.
Harley FXR's and FXD's also use the 12 1/2" shocks.
Posted : June 14, 2007 2:12 pm
Good to hear Doc. Next time you come over bring that shock we had with you and I'll give you the 20 bucks back. Hey at least it got you home 🙂
Posted : June 14, 2007 3:07 pm
