rear wheel noise
hey guys, i have a question; i drive a 650 V-Star with a rather light-weight sidecar, and i am getting a "popping" noise in the rear wheel in a left turn still drives okay; no jumping or skipping, just a popping noise.. has anyone else had this in a shaft drive??
Posted : January 20, 2012 4:06 pm
dumb question!
Posted : January 24, 2012 2:33 pm
i hope you found the problem?
Posted : January 24, 2012 3:06 pm
(@oldschool_iscool)
My guess is wheel bearings. Maybe the splines need inspection/grease. How much life is left on your rear tire? Maybe time for a rear hub overhaul when you change rubber.
Posted : January 25, 2012 3:19 am
The cuestion is from where it comes. Something has to move. points I had in my riding time were:
loose spokes
worn wheel ball bearings
worn swing bearings
or gap between frame and swing
I have no experience with shaft driven bikes. but there you could have worn ball bearings o to much play between the gears or worn cardanic cross joints.
Best luck seearching
Posted : January 26, 2012 4:44 am
thanks, tire is still in pretty good shape, i might have the rear hub checked out before time to replace tire.
Posted : January 27, 2012 6:06 pm
