Newbie to sidecars ...
Newbie to sidecars needs help
I have a 2001 Roadstar with a Champion Daytoa 2&2 side car, The car come off a 1999 Roadstar so I figures it would be easy to set up.I must have done something really bad 'cause it pulls like a bandit to the left. How do I correct this? The car has the electric tilt system but is is not hooked up yet.One more Question does anyone know of a shop within a reasonable distance from Fort Pierce Fl? Any help will be much appreciated Bill
Posted : October 10, 2006 9:31 am
Originally written by doubleburbon on 10/10/2006 1:31 PM
You came to the right place for help that's for sure, but just not from me...LOL Sorry.... I can't wait to see pictures, please post when ya can. I have a Daytona 2+2 on order and should be getting it in November sometime to drag my grand daughters around with me, it is being put on my VTX1300R by Dauntless Motors in Washington ... So I would love to hear all about your experiences with your new set up after you get the kinks worked out. You'll get help shortly from this BBS, they are a great bunch of folks here. ENJOY your new TOY
Posted : October 10, 2006 9:50 am
Bill,
I do not know anyone real close to you everyone is either north or south of you. There are some books on here at https://www.sidecar.com/links3.asp that will help. feel free to e-mail me I know some guys in the Miami that are always looking for a reason to ride and I maybe able to help you out.
Posted : October 10, 2006 10:57 am
Sounds like you have to much toe in on it. If you would like to phone me I will talk you through set up. I also may have the instructions from Champion for this set up.
Jay Giese
Dauntless Motors Corporation
www.dauntlessmotors.com
M-F 8-5 west coast time.
Posted : October 10, 2006 4:11 pm
Originally written by doubleburbon on 10/10/2006 3:31 PM
Too much toe in. You should be able to measure using two straight rails, boards, pipes (whatever) afixed securely on each side of the rig. Measure front then back at the specified locations for your combo and note the toe-in. Compare that delta to the specifications for your combo.
Posted : October 13, 2006 2:11 am
If using 2 straight edges to align for toe-in, just apply them against the rear wheel of the bike and the sidecar wheel. Most bikes have a different sized smaller diameter front wheel. The rear wheel determines which direction the bike will go with neutral steering. Measurements can be made directly below the axles of the bike. Some of the double wides will need an inch of toe-in. Most singles 3/4" or less.
Posted : October 13, 2006 12:33 pm
