Need shock for side...
Need shock for sidecar
(@gilberth)
The shock and spring are for my Jawa/Velorex 560.
I got the following dimensions off the old shock. Hoping someone can tell me what would fit.
Thanks,
Howard
Weight on s/c wheel 160 to 255 lbs
Shock max opened (relaxed) 11 3/8” eye to eye
Shock min length 7 3/4” eye to eye
Diameter of eye (top of shock) 10mm
Diameter of clevis (bottom of shock) 8mm
Width of eye 22mm
Inside width of clevis 20mm
Outside width of clevis 28mm
Outside diameter of spring 54mm
Inside diameter of spring 38mm
Coil thickness 8mm
length of coil 7 3/4’’
Posted : January 27, 2010 10:38 am
(@wingincamera)
I have been researching a replacement shock for my Champion Escort rig and found these two sites. I haven't purchased anything yet from either one, so no comment on their service. They are sold in pairs only, but the prices are decent.
http://www.hvccycle.com/mdischocks.htm
http://www.oldbikebarn.com/Motorcycle_Parts/Rear-Shocks
Posted : February 2, 2010 10:03 am
Why not take your measurements or old shock down to Bent Bike on Highway 99 in Lynnwood and see what they've got for cheap?
I've gotten good ones for 20 to 25 bucks.
Posted : February 2, 2010 11:37 am
(@George-Ryals)
Don't overlook ATV shocks. I found the perfect spring rate shocks on a Yamaha BigBear 350 ATV for my custom sidecar body suspension.
Posted : February 2, 2010 3:25 pm
(@wingincamera)
A used motorcycle parts place is a good ideal (like Bent Bike in Lynnwood). But my problem was trying to match up the spring weight that I would need.
Posted : February 2, 2010 5:08 pm
