Help Needed with 20...
Help Needed with 2011 Sportster & Sidecar rig.
Hack'n - 8/15/2011 12:46 PM
Are you guys using "Screamin Eagle" fork oil too? It helps reduce front end dive.
I don't recall the cross-reference of the wt's of the HD fork oils, but I used Maxima 10 wt as that was the brand available at the shop around the corner. It was an improvement; dive is damped quite well except in slam-on-the-brakes "panic" stops.
Posted : August 15, 2011 2:47 pm
