Harley Upper Mount ...
Harley Upper Mount Clunk
 kmev
(@kmev)
I'm getting clunking from the front, upper mount on my '72 Harley - mostly when turning in a tight radius and sometimes on large bumps. Is that normal, and how much should that spring be compressed? I greased the mount and tightened the nut so the spring was half compressed. Maybe I need to tighten it more?
I'm having fun with the rig and the ability to haul stuff around. The bike was little used in the last 5 years, so this is a welcome change.
Posted : April 14, 2015 3:33 pm
 46u
(@46u)
I would like to know this too. Mine has been making noise similar to what you are saying mine is more like a squeak for over 20,000 miles so far not a problem. I do recommend checking the torque on all fasteners. I have checked mine many times but yet found any loose.
Looking forward to what other have to say!
Posted : April 19, 2015 6:43 am
(@davet)
Can you post a picture of the mount? Not sure I know what the spring is you are talking about. Thanks
Posted : April 19, 2015 2:42 pm
Could it be just the clearance between the mounting bolt and the hole in the mount? Tightening the spring won't change this gap.
Posted : April 20, 2015 6:39 am
 kmev
(@kmev)
I am trying to post a pic of my mount, but I haven't been able to get it to work for the last few days.
Posted : April 23, 2015 5:54 pm
(@davet)
I have the newer TLE mounts so I don't have a spring on that mount. Maybe you can see if the mount is moving by using a zip tie or something.
Posted : April 24, 2015 1:52 am
(@timo482)
mine is newer and has a cone and a spring... with the cone it stays tight
Posted : April 24, 2015 5:49 pm
