Harley drum brake h...
Harley drum brake help needed
(@davet)
I put a new wheel cylinder and brake shoes on my 96 Harley sidecar. I have the shoes and springs back on but can't figure out how to put the shoe hold down spring clips on. The manual says to put them on last, do I need a special tool? Thanks, Dave
Posted : March 29, 2013 9:47 am
Will brake spring pliers work?
Posted : March 29, 2013 11:30 am
 46u
(@46u)
Hack'n - 3/29/2013 5:30 PM
No it is not for the springs but for the keepers that hold the shoes from moving out. I did a 59 pan a while ago same brake set up as yours. I have done many but it has been a while as I do not do them every day like I did 30 years ago. But my old brain tells me I think I put them on before the shoes.
Posted : March 29, 2013 12:53 pm
(@davet)
Yeah, I think before the shoes may be the way to do it even though the manual says otherwise. I tried that first but I was knocking them off when I stretched the return spring so I looked at the manual and now I can't get them on. You need to spread the clip and push it in to the slot in the back plate somehow. Later I'll try putting them on first again.
Posted : March 29, 2013 1:04 pm
 46u
(@46u)
Been working on Harley s for just about as long as I been riding them which is 42 years and I have seen a lot in the OEM manual that was not right. The OEM manual on mine cost me a inner fairing as they had two different torques for it in two different places and pulled out a insert.
Posted : March 29, 2013 1:25 pm
(@davet)
Another picture, 46u I know you know what it looks like.
Posted : March 29, 2013 1:30 pm
(@willy-g)
Went to look at mine in the garage, it's all apart leaning against the wall with the drum off.
I would try to get them in first also. Seems they would help to hold the shoe so you can install the spring next.
I really don't see how you could get that clip to tuck in with the other end already on the shoe, no room plus to much tension.
Posted : April 7, 2013 5:45 am
(@davet)
I took things apart and put those clips on first. One of them wanted to fall off so I used some masking tape to hold it on while I hooked up the return spring. Everything is together and I'm bleeding the brakes now so should be done soon. Thanks
Posted : April 7, 2013 10:36 am
