Front Tire
I'm using a Avon Triple Duty MKII tire on the front of the bike. It looks like it is "cupping". What may be causing that type of wear?
Posted : January 29, 2007 5:24 pm
It could be lots of things.
How many miles?
It also could just be a old and defective tire. I've used a bunch of these and noticed some are quite old when sold to me as a "new" tire.
Posted : January 30, 2007 5:23 am
The wheel/tire could be out of balance.
Dave
Posted : January 30, 2007 5:43 am
Only 1500 miles
Posted : January 30, 2007 9:45 am
Sloppy front end, Out of balance tire/wheel assembly, Out of round wheel. Any of these can cause cupping. An uneven vulcanizing process on the tire (sold as Seconds) can also cause uneven tread area wear.
I quit using 21" Avons in the '80's when I found that I could mount them with a teaspoon. That's how weak the bead was then. I figured if they went on that easily, how easy would they come off the rim and wrap around the axle with a flat. I've used Metzeler 880 Marathon and Dunlop Elite II's since. You won't mount them with a teaspoon.
Posted : January 30, 2007 12:46 pm
Lonnie, it's 19" Avon Triple Duty MKII. Thanks for the addition suggestions.
Posted : January 30, 2007 12:52 pm
