Extending forks
My Honda 1300 VTX/Ural rig only has 3" of ground clearance under the bike after the subframe was added. I have not had any problems yet but doubt I could get over a speed bump with it.
I was thinking of adding 2" fork extentions to gain ground clearance but wondered if that would adversely affect handling of the rig.
I have the rear shock set as high as it will go so only solution I know of would be to raise the front some.
Any ideas short of selling the bike and buying one with more ground clearance? I really do like the bike so that would be my last resort.
Fred
Posted : April 18, 2010 4:43 am
Adding the 2" to the forks would definitely improve the ground clearance. The steering might be just a tad harder. Maybe not even noticable.
Taller rear shocks would also help.
A 1" total gain in ground clearance makes a world of difference on a sidehack rig.
Posted : April 18, 2010 8:55 am
Thanks Lonnie. I will go ahead and get the fork extenders. I haven't been able to find a longer rear shock but maybe I can find one off another bike that will work.
Fred
Posted : April 18, 2010 2:05 pm
You might check with progressive suspension.
Posted : April 18, 2010 3:14 pm
Hey Fred: You might contact Dave Gardner of Ikon Suspension USA thru www.ikonsuspensionusa.com. Dave recently worked with me to build a set of rear shocks for our almost road-worthy K100/EML rig. The shocks were not "off the shelf" as, not only as a result of the custom EML swingarm with different mounts on each side, but also because I requested a non-standard length to accommodate a tire change. The Ikon shocks worked great on our first test ride.
Posted : April 18, 2010 3:25 pm
