Description of Cj75...
Description of Cj750 design and maintenance
CJ750 motorcycle maintenance requirements are simple, and can be carried out without the need for expensive special tools or special training. The motorcycle is designed to allow maintenance to be performed by the operator, and only major repairs will require skilled assistance.
Valve Timing Gear
The valve timing gear controls the intake of the fuel/air mixture into the cylinders and waste gas exhausted into the atmosphere. The intake and the exhaust valves are interchangeable on sidevalve engines, but not on OHV engines. The camshaft rotates in two bearings inside the engine crankcase, a ball bearing at the front and a bronze blind bushing at the rear.
Correct valve timing is obtained by aligning the mark grooves on the timing gears. This must be carefully observed during disassembly and reassembly of the engine.
the article from http://www.motor-sidecar.com
Posted : February 6, 2012 2:55 am
 VLAD
(@vlad)
msidecar - 2/6/2012 7:55 AM
Valve Timing Gear
Hey msidecar. Your talking like salesman for CJ750....
Posted : February 6, 2012 12:23 pm
hi vlad,i'm a salesman for cj750,i like sidecar , it's so beatiful now! Our company sale cj750 sidecar over ten years, if you want to get a sidecar or some questions about cj750 sidecar,you can contact me,i'm glad to meet you!
Posted : February 8, 2012 5:45 pm
 VLAD
(@vlad)
I don't think Technical Discussion is good place to do your sales. Also I know CJ is a very bad chinees copy of not so good russian copy of 1938 BMW.
If you want to sell something you can post it in Complete Rigs For Sale or Sidecar For Sale.
Posted : February 9, 2012 6:45 am
 VLAD
(@vlad)
Quote" CJ sidecars from china we found that quality was all over the place on the Chinese CJ sidecars some to the point of not being safe as the frames welds were very poor and hidden with bondo so we stopped importing these. "
Read this b4 you buy from http://www.motor-sidecar.com
Posted : February 24, 2012 1:31 pm
