Correct set-up?????...
Correct set-up????????
I'm new at this sidecar stuff. I have a 1978 R100/7 BMW with 1978 Ural hack. I'm always sterring left to go straight. The toe-in is at 3/4, and the lean out is 1/4 at the top of a 2ft square. These are un-weighted measurements. There is 5/8" difference is handle bar height, with the left side lower. Am I close on these setting? I would like to take a long trip (1700 miles)but I'm concern that it may be to tiring as compare with two wheels
Posted : June 27, 2007 7:04 am
Quack,
reduce your toe in to 1/4". then lean the bike out some more. keep leaning until it tracks straight at the speed you want it to. usually 60-65 MPH.
set this lean with you on the bike and a passenger and/or ballast in the SC, if you haul one.
Posted : June 27, 2007 7:33 am
Bob has given you some good advice. There is another current thread about a harley asking the same questions.
Posted : June 27, 2007 8:59 am
Yeah, you cant go by the book here , just because someone told you you need 3/4" toe-in and 1/4 " lean. this has to be the seat of the pants 'set and test' method.
every bike/SC combo has different needs.what you have is a basic starting point for the lean setup...some need more, some less. some HD's use lean IN!!
Posted : June 27, 2007 10:17 am
Thanks for the help. I've gotten some of my info from old Hacked maz. and the Sidecar Industry Council. What is a good source of ballast, and how much should I use?
Posted : June 27, 2007 11:36 am
Try the link below.
http://www.sidecar.com/megabbs/thread-view.asp?threadid=4578
Hope it helps
Posted : June 27, 2007 12:01 pm
